new update: 40+ new UI's for plugins
nyukuri
- ram: 4GB
- Hard_Drive_Capacity: 500GB
UPDATED: July 22 2012
I did some changes to my plugins as well as to some original tools. They are now a bit harmonized, better looking and the layout is usually kept when resizing. Often they are smaller, because I use ASP mostly on a laptop with small screen resolution. I have added a zip file with all the UI's. Just unpack and then copy the files into their respective folders.
Example destination folder for a plugin (CAQuest):
C:\Users\...\AppData\Local\Corel\AfterShot Pro\Plugins\CAQuest.afplugin\ui
Example destination folders for original tools:
C:\Program Files (x86)\Corel\Corel AfterShot Pro\supportfiles\tools
C:\Program Files (x86)\Corel\Corel AfterShot Pro\supportfiles\tools\Advanced
C:\Program Files (x86)\Corel\Corel AfterShot Pro\supportfiles\plugins\Black and White.afplugin\ui
etc.
ATTENTION, the changed UI's are in ENGLISH and may not work well if you use ASP with another language setting!!!!
For the original tools you need to use Windows Explorer to copy with Admin rights!
New installations of plugins will of course overwrite the changes! My UI's may no longer be right if the plugin author introduces new functionalities in future versions. But at present (July 22 2012) the UI's are all for the latest versions.
nyukuri
PS: have a look at the following posts for preview images and a list of changed plugins/tools
UPDATED: July 22 2012:
etc.
nyukuri
- Attachments
- new ASP UIs.rar
- over 40 new interfaces for ASP plugins and tools
- (126.38 KiB) Downloaded 533 times
nyukuri
- ram: 4GB
Re: new UI's for plugins (TEXA layout now makes sense!)
here a list of the UI's I changed and which you can find in the attachment of the first post:
asGPS, AutoLevels, Basic Adjustments, Bez, Black and White, CAQuest, Color Balance, Color Equalizer, Color Management, Curves, Exposure, FatToni, Grain, Grid, Keywords, LensCorrection, MathBox, Mix3, Presets, RedEyes, SContrast, SiliconBonk, SplitToni, Texa, TypeWriter, USM, Vigne, WhiteBalance, 2x Wavelet Denoise, 2x Wavelet Sharpen, zChannelMixer, zFrame, zPerspector, zShadow, zSoften, zText
+ 4 mini plugins for the Standard tab (see readme.txt)
nyukuri
- ram: 4GB
New: smaller and clearer Wavelet UI's
I use ASP on a small Laptop screen, so to fit the Plugins better on the screen, I made them smaller.
Wavelet Sharpen and Denoise can be a bit confusing with their many options, by placing these on different tabs, the layout becomes easier to understand.
claudermilk
Looks nice. I'll give it a try.
Bibble transplant
kaymann
- motherboard: ASUS P8P67 PRO REV 3.1
- processor: Intel i-7 6800K
- ram: 32 GB
- Video Card: NVidia GeForce RTX 2060
- sound_card: Onboard
- Hard_Drive_Capacity: 3.5 T
- Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
- Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
I tried several of them and they look nice - You spent alot of time on this good job - Where/what is mathbox?
nyukuri
- ram: 4GB
Thank you for the compliment!kaymann wrote:I tried several of them and they look nice - You spent alot of time on this good job - Where/what is mathbox?
I had presets that needed MathBox, so I looked for it and just have it now for a few days. It allows you to type in mathematical formulas for each color channel. (R=r+(((b+g)/2)-r)*(x/400)) etc.
It's something for tech geeks who like to experiment or understand very well the RGB system...
afx
- System_Drive: N/A
- Video Card: FirePro 4900
nyukuri already answered the what.kaymann wrote:Where/what is mathbox?
Where: http://afximages.com/stuff/plugins/
cheers
afx
nyukuri
- ram: 4GB
Thank you afx for the reply to that question, I had overlooked the "Where"...
Thanks.
I tried.
Have a nice day.
I tried.
Do you know where are the folders in mac and linux ?nyukuri wrote: Example destination folders for original tools:
etc.
Have a nice day.
deifl
- System_Drive: Z
- motherboard: Belarc Advisor do not work on my systems
- processor: Belarc Advisor do not work on my systems
- ram: avg gt 4GB
- Video Card: Belarc Advisor do not work on my systems
- sound_card: availible
- Hard_Drive_Capacity: avg gt 2TB
- Monitor/Display Make & Model: 10" to 24" (12.5" and 24" IPS)
For Linux:cch44 wrote:Thanks.
I tried.
etc.
Have a nice day.
/opt/AfterShotPro/supportfiles/tools
/opt/AfterShotPro/supportfiles/tools/Advanced
/opt/AfterShotPro/supportfiles/plugins/Black\ and\ White.afplugin/ui
Hope it helps
Thanks.deifl wrote:For Linux:cch44 wrote:Thanks.
I tried.
etc.
Have a nice day.
Hope it helps
patrickh
- System_Drive: N/A
- motherboard: Macintosh
- processor: 2.93 GHz Intel Core i7
- ram: 4GB
- Video Card: ATI Radeon HD 5750 1024 MB
- sound_card: MacNone
- Hard_Drive_Capacity: 1Terabyte
- Monitor/Display Make & Model: iMac 27"
Thank you nyukuri
patrickh
patrickh
