I've created a dvd slideshow and also added two music tracks to it. I then used the original file and put two different music tracks on it. I hoped it would then play the slideshow twice and I would hear 4 music tracks (i also want it to repeat continuously).
When I used Share- Create Disc the disc played as I wanted it to on my computer, but when I play it in the dvd player at work it just plays the first video with the first two songs on and keeps repeating this.
Is there a tick box I've missed somewhere for it to play both the videos on a loop not just the first one?
Several videos on one dvd
dumbdumber
- motherboard: ASUSTek Computer inc
- processor: 3.10g Intel Core i3-2100
- ram: 4gb
- Video Card: nvidia
- sound_card: realtek ac97
- Hard_Drive_Capacity: 477gb
- Monitor/Display Make & Model: Philips 223e
Re: Several videos on one dvd
you may need to combine the two videos into one for a DVD player to play through both - you then need to tick the box against "Auto repeat when disc playback ends" in the 'project settings' box in the BURN module.
this as you say should work on a computer - but whether it works on a standalone DVD player depends entirely on the make and model number of your DVD player - some do some don't.
dumbdumber
- ram: 4gb
Thanks, although I'm sure I did it this way last time and it was ok.
Is there an easy way to copy the second video onto the end of the first ? It's just that it's quite a long slideshow and I don't want to have to mess around with all of the text etc again.
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Use nesting projects, search the help file if you don't know how to do it, or save the 2nd project as a video file and import it into the first project
dumbdumber
- ram: 4gb
Thanks everyone, I've imported the other video files onto the same project and it seems to be ok now.
