XMP files
pgman
operating_system: Linux
System_Drive: N/A
XMP files
Post by pgman »
I'm not here to restart the debates on the XMP implementation with Bibble/ASP, BUT...
Is there a way of setting ASP to generate the standard XMP file at the same time as the ASP .cr2.XMP or .nef.XMP file so that other software can view the IPTC information?
I have forgotten too many times to generate the standard XMP, then I have a hard time finding the photo for which I should generate the standard XMP file.
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: XMP files
Post by afx »
Unfortunately not ;-(
cheers
afx
andreas
System_Drive: X
motherboard: Asus in Workstation and Dell XPS Notebook
processor: i7-980 and i7-2720QM
ram: 12GB - 8GB
Video Card: ATI FireGL
sound_card: on board
Hard_Drive_Capacity: 4.5TB Rd10
Monitor/Display Make & Model: Samsung Syncmaster 2343sw
Re: XMP files
Post by andreas »
bash is you friend.. save this as checkForDefaultXMP, make executable and call with the path to check as its argument:
Code: Select all
#!/bin/bash
# if argument is directory check it
if [ -d "$1" ]; then
	find "$1" -name "*.xmp" -exec checkForDefaultXMP {} \;
	exit 0
fi
# image argument...
# image name to check
IMG="$1"
ORG=$IMG
# raw patterns to include
IMG=${IMG%.nef.xmp}
IMG=${IMG%.cr2.xmp}
# no match for default xmps
[ "$ORG" = "$IMG" ] && exit 0
[ -f "$IMG.xmp" ] || echo "no default XMP for: ${ORG%.xmp}"
exit 0
Use with care, only quick test done. You can add more raw patterns in the script.
Andreas
Linux - not Windows
