I'm on the road with an older laptop and Ubuntu 10.04 with ASP 1.0.1.10. The laptop has a 15.4" 4:3 older style display. My problem is the layout:
Is there a way of starting in thumbnail view?
Screen layout
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Screen layout
No, you need to switch manually.
Also, if you have primarily portrait images, CTRL-L will flip the thumb strip to the side (if you have not discovered that yet)
cheers
afx
cheers
afx
