Pro X5 how to change volume
cdoughertycd
motherboard: ASUS PHTD DELUXE
processor: 4 Core 2-93 gigahertz Intel Xeon
ram: 36 GB
Video Card: AMD Radeon HD 7700 Series
sound_card: AMD HD Audio
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Samsung S24B300
Corel programs: many back to VS 5, all up to 2022 Ult
Post by cdoughertycd »
Hi: I have a project with many clips. I am trying to change the volume on all of them to the same level. I tried shift click on the first clip and then the same on the last one to group them all. They group but I can't change the volume for all of it. Do I have to change volume separately on each clip?
If so, is there an easier way other than dragging the little markers up and down when I'm on the volume timeline?
thanks for your help.
Candy
Re: Pro X5 how to change volume
Post by BrianCee »
The easiest way to change the volume of individual clips is to use the volume control in the options panel - do not go into audio view - click on the clip and open the options panel and you will see the volume control at top left under the video tab, by default it is set to 100 but you can vary it up to 500, click on the single downward pointing arrow to the right of the 100 to get a volume slider - the small up and down arrows make very small changes.
If you want to vary the volume throughout the clip then use audio mode and play the clip and use the master volume slider in the mixer panel to adjust the sound continuously throughout the clip.
I have never found a way to vary multiple clip volumes all together
cdoughertycd
ram: 36 GB
Brian, thanks for your help. I appreciate it.
Candy
