MathBox for ASP
AfterShot Pro Plugins
nyukuri
ram: 4GB
Hard_Drive_Capacity: 500GB
MathBox for ASP
Post by nyukuri »
Is there already MathBox out for ASP or any plugin replacing it? I have some presets that need MathBox.... :(
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: MathBox for ASP
Post by afx »
There is a quick hack (and the source code) at
http://www.afximages.com/stuff/plugins/
I have a slight better version on my disk where MB is placed before Perfectly Clear making it more suitable for channel swapping.
But currently I only have Linux compile environment...
cheers
afx
nyukuri
ram: 4GB
Re: MathBox for ASP
Post by nyukuri »
Thank you!
So I just hope and wait for the win version :)
afx
System_Drive: N/A
Re: MathBox for ASP
Post by afx »
If you are desperate, the referenced version already runs on Windows.
It is just the pipeline position that might not be optimal depending on your needs.
cheers
afx
nyukuri
ram: 4GB
Re: MathBox for ASP
Post by nyukuri »
thank you, I downloaded it already!
Since you mentioned the pipeline, is there any way to get to know the pipeline of ASP, for the original tools as well as the plugins? I am really interested to know WHEN something is applied to my image.
afx
System_Drive: N/A
Re: MathBox for ASP
Post by afx »
Check the AfterShotPro.log file in your AS user directory.
There you can see the complete pipeline.
cheers
afx
