VSX5 audio rendering problem
ergalarza
motherboard: Dell Inc. 0Y2MRG A00
processor: 2.90 GHz Intel Core i5-2310
ram: 8176 Megab
Video Card: AMD RADEON HD 6450
Hard_Drive_Capacity: 1Tb
Monitor/Display Make & Model: DELL S2309W
Corel programs: VSX7-VSX8 ULTIMATE 18.6.0.6 SP
Post by ergalarza »
Hello, I am editing an AVI file (please see video file specs below), mainly splicing work, with VSX5, and when rendering the video file (please see Project Features below, sorry for the Spanish) the sudio "blips" inintelligiblely for 2 or 3 seconds between continuous clips (in every joint between clips). I tried the following alternatives:
- Rendering audio only file: no change
- Eliminating fade-in/fade-out in video track: no change
- Splitting the audio of all video clips and placing it on the voice track: no change
- Splitting the audio of all video clips and placing it on the music track: no change
I have mostly worked with MOV files using the same Project features, and have never experienced such trouble.
Eagerly waiting for your kind advise, and thanking you in advance for it
ESTELA
PROJECT FEATURES
(Pérdida de marco NTSC (29.97 fps)
Archivos MPEG
24 Bits, 720 x 480, 29.97 fps
Basado de cuadro
(DVD-NTSC), 16:9
Velocidad de datos de vídeo: Variable (Máx. 8000 kbps)
Velocidad de datos de audio: 256 kbps
Dolby Digital Audio, 48 kHz, 2/0(L,R)and when rendering
VIDEO FILE SPECS
Format : AVI
Format/Info : Audio Video Interleave
File size : 894 MiB
Duration : 1h 21mn
Overall bit rate : 1 530 Kbps
Writing application : MEncoder 1.0rc2-4.2.4
Writing library : MPlayer
Video ID : 0
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 1h 21mn
Bit rate : 1 438 Kbps
Width : 624 pixels
Height : 256 pixels
Display aspect ratio : 2.40:1
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.360
Stream size : 840 MiB (94%)
Writing library : Lavc51.44.0
Audio ID : 1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 21mn
Bit rate mode : Constant
Bit rate : 80.0 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 46.7 MiB (5%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (0.65 video frame)
Interleave, preload duration : 522 ms
Writing library : LAME3.98
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Re: VSX5 audio rendering problem
Post by teknisyan »
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
