I have a Pentax K-r and a Pentax DA 18-250 lens .
If I shoot in JPEG or DNG, AfterShot Pro never auto-detects the lens.
If I shoot PEF, it auto-detects it correctly.
I know the lens information is also in the JPEG and DNG files because the Pentax tool correctly detects the lens in all 3 types of files.
I tried to attach some samples straight out of the camera, but even shooting at 2MP with the lowest quality, the JPEG attachment would be bigger than the 256KB limit allowed. I don't want to use an editor which might mess up the EXIF . The RAW files are 18MB each.
Lens detection : works with PEF, not JPG or DNG
madbrain
- motherboard: Gigabyte GA-990FX-UD3
- processor: AMD FX-8350
- ram: 32GB
- Video Card: nVidia GTX 750Ti
- sound_card: ECHO Audiofire 12
- Hard_Drive_Capacity: 5TB
- Monitor/Display Make & Model: HP LP3065 30" x 2 + Asus PA238Q 23" x 1
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Lens detection : works with PEF, not JPG or DNG
Sent it to the monkey (see signature).
cheers
afx
cheers
afx
madbrain
- ram: 32GB
Sent! Files are in upload # 332 . didn't get a bug number for the detailed submission .afx wrote:Sent it to the monkey (see signature).
cheers
afx
madcow
- motherboard: ASUS P7P55D-E Deluxe
- processor: Intel Core i7 860 2.8GHz 8MB LGA1156
- Video Card: XFX ATI Radeon HD 5770 1GB DDR5
- sound_card: On-board VIA VT2020 10-Channel HD Audio
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Dell UltraSharp U2410
I have the same problem with Pentax K10D generated DNGs (but not with PEFs).
Reported to the monkey, file upload #336.
I had this problem (amongst others)
I found fix using a script during import. It works with JPGs, and it should work with DNGs since Exiftool is supposed to handle them, but I can't check.
See http://forum.corel.com/EN/viewtopic.php ... 89&start=0
Hi there, I have the same problem, any chance it will be fixed?
Cheers.
Cheers.
