This goes in "profile_sony.txt" in place of the existing block with zeros:
begin lens
group: sonyemount
multiplier:1.5
aperture: 3.5
menu_lens: Sony E 18-55mm f/3.5-5.6 OSS
cal_abc: 18.0 0.025590 -0.086399 0.046144
cal_abc: 21.0 0.031353 -0.089208 0.057472
cal_abc: 24.0 0.034082 -0.098398 0.083739
cal_abc: 28.0 0.012071 -0.027476 0.030799
cal_abc: 35.0 -0.003121 0.025128 -0.016311
cal_abc: 45.0 -0.001392 0.012881 -0.000238
cal_abc: 55.0 0.008579 -0.017748 0.022726
end
Note that this formulation requires the following entry in "profile_sonyemountlenstable.txt" - the file as shipped should already have it:
E 18-55mm F3.5-5.6 OSS|Sony E 18-55mm f/3.5-5.6 OSS
I've done this using PTGui. It seems to work, but as I've taken a different approach to other profile creators, I'd appreciate if someone could test it and confirm that it's ok.
Note that the NEX cameras do not seem to be auto-recognised. I think that this is because the camera ID is in maker notes and not standard EXIF, which is a real pain.
F_P
Lens Calibrated: Sony E 18-55mm f/3.5-5.6 OSS for NEX
ferdinand-paris
- motherboard: GA-X58A-UD3R
- processor: 3.20 gigahertz Intel Core i7 960
- ram: 4Gb
- Video Card: NVIDIA GeForce 7300 GS
- sound_card: Realtek High Definition Audio on-board
- Hard_Drive_Capacity: 2500 Gb
- Monitor/Display Make & Model: Eizo CG222W
wwinter86
- System_Drive: N/A
- processor: 3.4 GHz Intel Core i7 2600
- ram: 8 GB
- Video Card: AMD Radeon HD 6970M 2048 MB
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: iMac 27"
Re: Lens Calibrated: Sony E 18-55mm f/3.5-5.6 OSS for NEX
Does this work for the Alpha A-mount version of the lens?
ferdinand-paris
- ram: 4Gb
You can try, but I can't imagine why it would work, other than by extreme luck. After all, my understanding is that it's a different lens with a different optical design, even though it's covering the same size sensor over the same focal lengths. It has to be, given the much shorter lens to sensor distance.
You've made a number of posts today that suggest that by doing so your views will come to the attention of Corel. However this is a user-to-user forum and it's unlikely that they will. You might get lucky, but my advice would be to find a way to send them direct. The surveymonkey used to be the official route, but I'm not sure that it's working any more.
