Global Filters not working properly
I should know how to correct this, as I think I've ran into this problem before. However I can't seem to remember what I done to fix it. So I would greatly appreciate some ideas on why and how to correct it.
The Problem
When applying any of the Global Effects to a Text Object it does not apply it to the text. Instead it is applied to a shape surrounding the text. There is no such shape. It appears as if the Text has been converted to a Vector object, which it has not. The screenshot shows this.
I've re-installed the program numerous times to no avail. I also have MS3D installed on my old WinXP machine, and do not have this problem on that machine. The problem is occurring on my laptop, running Windows Vista. My laptop is a Compaq C700...
Video/Monitor Info
Driver Version: 7.14.10.1437
Operating System: Windows Vista (TM) Home Premium* , Service Pack 2 (6.0.6002)
Default Language: English
DirectX* Version: 10.0
Physical Memory: 2037 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 358 MB
Graphics Memory in Use: 163 MB
Processor: x86 family 6 Model 15 Stepping 13
Processor Speed: 1729 MHZ
Vendor ID: 8086
Device ID: 2A02
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel(R) 965 Express Chipset Family
Video BIOS: 1533
Current Graphics Mode: 1280 by 800 True Color (60 Hz)
Direct X is up to date. As I previously stated, I think I have came up against this same problem before, however just don't recall what I done to correct it.
You do not have the required permissions to view the files attached to this post.
Re: Global Filters not working properly
Hi Ron
Nice to hear from you, hope you are keeping well...
I have tried using my XP PC and as you say it seems ok, when I can get on the laptop I will give it a go, that has W7 installed, maybe has similar effect as Vista.......
I assume the fix was a tweak using MS3D and not the laptop??
Hi Trevor,
Yes doing fine, and hope you are too!! Been keeping real busy working, away from home during the week, and only home for the weekends.
I would guess that the fix is either with MS3D, the OS, or maybe even my Graphics drivers.
Hi Ron
Can you save the project as a c3d file and e-mail to me.
At least i will be looking at the same beast.
Trevor, yes I can, however I've already determined it's not the file or program. I copied the file from my Vista machine to the WinXP. Opened it and it works as it should on WinXP. So I think it is some setting on my Laptop. I've been through all the Intel Media Graphics settings, checked the Direct X, ect., and still no glory.
Hi Ron
Have you tried running the program in Compatibility mode for XP
Yep, I have tried running it in WInXP compatibility mode, nothing changed. I looked at the file you sent and it plays fine on my laptop. Still don't know why the program is behaving like it is. It must be something with my laptop, just not sure where else to look.
PEGACON
motherboard: Intel
processor: Pentium4 3Ghz
ram: 2GB
Video Card: Geforce4 TI 4600
sound_card: Realtek
Hard_Drive_Capacity: 160GB
Post by PEGACON »
Hi RON.
I'm a Korean and I live in South Korea.
I'm not speak english very well so, I ask to be excused.
English translator was used.
In my opinion, I think you need to think of many situations. Solution is very annoying.
In your Laptop computer,
1. A new installation of Windows Vista does not solve the problem, install Windows XP.
2. Install Windows XP does not resolve the problem, the problem is not OS. Direct X will therefore not be an issue too.
3. If so, the problem is the graphics card. Graphics card driver version at least 1 year interval between the two drivers
that I see the version file to test.
4. Good Luck.
By the way, you said,
"I've already determined it's not the file or program"
"I looked at the file you sent and it plays fine on my laptop"
That mean, your OS or the Graphics Card or Dirct X be a no problem?
Others sent files to normal operation. But when you're working yourself to that problem, I do not quite understand.
In that case, both sides have got a problem it is normal.
Other features of your Easypalette window is normal? Seems to be a bug report.
Yes, I figured that reformatting and reinstalling Windows would cure it. My problem right now is I don't have the time. I also discovered something strange. Even though it does not show properly in the view window, It does render out correctly. So as I can find the time, I'll continue looking into this.
Thanks Pegacon for having a look at my problem.
I figured it out :D
I knew it was a problem with my laptop, specifically it had to be something wrong with my graphics settings/drivers. I had tried numerous times to update them, but kept getting an error, saying that my OS was not supported. :o Long story short, I finally found where I could get the software/drivers to update, and that fixed my problem.
Thanks Trevor and Pegacon for considering my problem!!!
Now you can relax and have a nice day
PEGACON
motherboard: Intel
ram: 2GB
sound_card: Realtek
Post by PEGACON »
I'm glad, everything was resolved well.
