How To Create a Watermark
Loy
motherboard: Dell Inc. 0YD479
processor: 1.87 gigahertz Intel Core Duo
ram: 2GB
Hard_Drive_Capacity: 250GB
Monitor/Display Make & Model: ATI Mobility Radeon X1400
Post by Loy »
I am trying to create a visible watermark to apply to pictures. Does anyone know how to create one to use in Paintshop Pro X4 Ultimate? I know how to apply one but I'm uncertain on how to make the actual watermark.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: How To Create a Watermark
Post by LeviFiction »
A watermark is nothing more than an image that you make.
So make any image you want, use any images or text, whatever it's your watermark, then save it as a PNG (especially if you want transparency on it). You say you know how to apply it but just to make sure there are two common ways.
1) Open the image and copy it onto its own layer on top of the current image and set the transparency and blend mode of the watermark layer to whatever you want it to be.
or
2) Use the Watermark command and follow its settings for applying the watermark.
Very simple. There is really nothing special to watermarks other than the fact that it's something you have made yourself.
Loy
ram: 2GB
Post by Loy »
Levi,
So I created a 4x6 image and inserted just text to keep it simple. Now to getting the watermark on the picture. Your option 1 below works just fine the only thing is that I have to go back and resize the watermark picture to make it look right on the picture. option 2 below does not work. I can get the file to pull-up just fine and can even see it in the sample window but, I cannot get the thing to show up on the image anywhere and it seems to freeze-up the program because then I can't select OK or Cancel to get out of it. I have to shut the whole program down just to get out of it. Is there something I'm over looking?
brucet
operating_system: Windows 8.1
Post by brucet »
I created a watermark. (Text on a transparent background). I saved it as a PSP file. As most of my files are the same pixel size I saved the 'water mark' file at the size I wanted it to be on most of my files.
Then the very last thing I do to is load the 'water mark' file. Copy. Then paste as a new layer on my work file. Then I can adjust the opacity, size and location to suit.
If need be the file can be saved as a PSP file thus retaining the layers or merge the layers and save as a tiff or jpeg. I adjust opacity because each file is different and some files don't need as much opacity.
I find this far more flexible than using PSP's watermark function.
regards
Loy
ram: 2GB
Post by Loy »
Thanks Brucet! I'll give that a try.
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
You can follow this tutorial that I created for PSP X2... you can still apply it to newer version of PSP.
http://abielonline.blogspot.com/2009/10 ... hotos.html
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
