Renaming library folders
larschristian
operating_system: Linux
System_Drive: N/A
motherboard: ASUS something
processor: AMD Phenom II X6 1090T Processor
Video Card: ATI radeon something
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Dell 2312HM + Samsung SM913v
Post by larschristian »
My directory structure is
[YEAR]/[MM-DD]
So when importing from my camera can in example get:
/2012/05-28/
/2012/05-29/
This is also the name the library folders get in the catalog. I'd like to rename these with some keywords like:
/2012/05-28_trip_to_the_zoo
/2012/05-29_Spider_session
How do I rename a library folder? Only method I've found is to create a new library folder and then move the photos over.
I could change the name in the file system, but then I'll have to delete the library folder and import the renamed folder.
I could also rename folders before importing the folders, but then I can't use the Download batch to get the files off the SD card.
Is there a smooth way to do this, or do I need to change my workflow somehow. I know about keywords, but that is not the solution I'm looking for. I want to rename the folders.
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Renaming library folders
Post by afx »
larschristian wrote:I could also rename folders before importing the folders, but then I can't use the Download batch to get the files off the SD card.
Why not???
Check the jobname rename variable....
cheers
afx
larschristian
System_Drive: N/A
Thanks!
Changed subfolder to [month]-[day]_[jobname] and checked "Ask each time for jobname". That works perfectly! Now I only need to group the files to download into several batches if I have more than one event on the card. That's easy!
:D :D :D
My workflow is yet again smooth and perfect. Simple and perfect solution.
But now what to do with all my folders just named [MM-DD] without jobnames... I still want a rename function. Not so important anymore, but on my wishlist for future versions. :wink:
