How do I move files on import?
sinisterbrain
operating_system: Linux
motherboard: Intel
processor: Quad Core I7
ram: 32Gb
Video Card: Nvidio Quadro NVS
sound_card: not applicable
Hard_Drive_Capacity: 6Tb
Monitor/Display Make & Model: 2x Dell 30in
Post by sinisterbrain »
I'm a long time Bibble user, and I just converted to AfterShot-Pro. Bibble has been an intigral part of my professional workflow. I'm afraid AfterShot changed a few things that actually make it less intuitive - at least to me.
In Bibble I used to use a Batch to recursively import files of my CF cards - MOVING them into my catalog and renaming them in one swift move.
The batch import no longer seems to work the same. - It moves and renames the files on my CF card.
How do I get a single hotkey to import and MOVE the files into my catalog as bibble used to?
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: How do I move files on import?
Post by afx »
The silly move into catalog has been dropped.
Catalogs are only by reference in AS.
Just copy to a decent tree structure on the hard drive in the download queue and let it import at the same time.
cheers
afx
sinisterbrain
motherboard: Intel
ram: 32Gb
How is moving silly?
I used Bibble for years to import and organize my files in one swift move. So you're saying I have to open up a file manager, manually copy the files to my raid, then once that's complete return to AS and then import?
afx
System_Drive: N/A
Post by afx »
sinisterbrain wrote:How is moving silly?
Directory structure has more layers than needed.
Using the files via other software might introduce files in the catalog that the cataloger gets funky about.
Any serious DAM I've ever touched worked with uses referenced files.
No!
Use a download queue in AS to copy stuff to your HD with sensible paths and file names and switch on importing if you desire, for example:
Download destination fixed to /data
Image name: [jobname]-[YEAR]-[MONTH]-[DAY]-[3jobseq][<oext]
Subfolder [YEAR]/[MONTH]/[YEAR]-[MONTH]-[DAY]-[jobname]
cheers
afx
sinisterbrain
motherboard: Intel
ram: 32Gb
I'll give it a try.
Pixel Ninja
motherboard: Asus P79WS
processor: Intel i7
ram: 64 GB
Video Card: Dual GTX 980
sound_card: Focusrite Saffire Liquid 56
Hard_Drive_Capacity: 4TB+
Monitor/Display Make & Model: 3 X Asus 24" IPS monitors
Corel programs: PSP Ultimate and VS Ultimate
Post by Pixel Ninja »
afx wrote: Use a download queue in AS to copy stuff to your HD with sensible paths and file names and switch on importing if you desire, for example:
Okay, this is totally confusing to me. I understand the code and the concatenations, but have NO idea how or where to apply this in ASP.
A search in the help/PDF for "download queue" yielded nothing useful.
RickHeath
Post by RickHeath »
I don't use the download but I presume it is being suggested that you edit the Download batch - the marked boxes in the attached image. You can find these in the, slightly confusing for this purpose, Batch Outputs by right clicking & choosing Settings.
Rick.
afx
System_Drive: N/A
Post by afx »
Pixel Ninja wrote:A search in the help/PDF for "download queue" yielded nothing useful.
Because the download batch queue is not a fixed part of AS, but one use of the batch queue system.
As Rick already pointed out, it is one of the predefined queues in the output tab.
Batch queues are not only used for output generation, but can also be set to copy and import files and are therefore usable for downloading.
cheers
afx
Dutchmm
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Post by Dutchmm »
What I found confusing about using the download queue was the fact that you had to start in the file system tab rather than in the Output tab. If I might say so, this is an area in which AFX could usefully improve on the BSG when the ASG comes out.
To summarise, you can make the changes to the Download batch by bringing up the settings page. Choose the Output tab in the left hand window. Look for D in the "Batch Output" sub-window. Double click. You now see the pane which Rick included in his post. Put the settings in the boxes he points at. OK.
Now click the "File System" tab in the left window, Expand the tab until you see your photo card, Now right click the volume. The third item on the context menu is "Send to batch (including subfolders)". When you put the mouse on this item, you will see another menu appear - the list of the batches. This is where you can choose the Download batch. And Bob's your uncle!
HTH
Mike
afx
System_Drive: N/A
Post by afx »
Dutchmm wrote:What I found confusing about using the download queue was the fact that you had to start in the file system tab rather than in the Output tab. If I might say so, this is an area in which AFX could usefully improve on the BSG when the ASG comes out.
Me thinks this is clearly explained in BSG already.
Where exactly do you see a need for change?
cheers
afx
Dutchmm
System_Drive: N/A
Post by Dutchmm »
To answer your question:
  • 1, Download queues have only one index entry, page 196 IIRC, IMHO, if this subject deserves only one index entry, it should point at page 110
    2. The text on page 196 doesn't point to the text on page 110 (to be fair, given the subject matter, you wouldn't expect it to, except for it being the only indexed entry)
    3. Text searches for "download queue" throw up several false positives before you get to page 110
    4. Even then, it is only the 4th paragraph in 5.7.1 that mentions the need to approach the queue from the file panel's context menu
    5. I felt this was a subject that could have benefited from some illustration
I offered the comment as a constructive suggestion, because as useful as I find the BSG, I have occasionally had to look beyond it to find out how to do some things - this was one of them. FWIW, I thought a worked example of copysets would have been handy as well. I look forward to the appearance of the ASG, and if you are looking for a beta tester, I would be very happy ....
Mike
afx
System_Drive: N/A
Post by afx »
Thanks for the detailed feedback!
Dutchmm wrote:1, Download queues have only one index entry, page 196 IIRC, IMHO, if this subject deserves only one index entry, it should point at page 110
Actually, it is two entries, one for the file (196) and one for the batch to page 133, where the concept is explained together with a sample queue definition.
On page 110 there is only a highlevel description of downloads that then points to page 133, so I think the index entry for 110 would not help that much. After all the stuff in chapter 5.7 is just a quick wrap up and the meat is on page 137.
Yup, that is just an explanation of default files, but, think you have a point here, I'll update the whole file reference chapter with pointers to where the file use described that will make this chapter more useful. In case of the download queue it would point to page 137 then of course.
Yes, otherwise I could not reference download queues at all ;-)
Yes of course. First you set up the queue and then you use it...
Describing how to access the queue without first giving the information on how to set it up, will lead to people downloading with the shipped defaults which I think is not good practice.
5. I felt this was a subject that could have benefited from some illustration [/list]
Really?
I thought it way to trivial to even think about an illustration. What would you have there?
Hmm, if I do a screen shot, it would be basically the same as selective copy (which I referenced), so my thinking was that this is redundant, therefore I just listed the items that I think are useful for copy sets. ASG has a bullet list now that reads a bit easer than the list in the text....
thx
afx
