[SOLVED: User Error] Kubuntu 12, no 3rd party plugins work.
sinisterbrain
- motherboard: Intel
- processor: Quad Core I7
- ram: 32Gb
- Video Card: Nvidio Quadro NVS
- sound_card: not applicable
- Hard_Drive_Capacity: 6Tb
- Monitor/Display Make & Model: 2x Dell 30in
I just rebuilt my system to Kubuntu-12 64bit, and at the same time converted from Bibble 5 to Aftershot Pro. AfterShot operates fine, though none of the plugins I've downloaded from Corel work.
This is a sample error message I get from Aftershot:
40273.327: Loading plugins
40273.328: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/zText.afplugin"
40273.328: "Plugin library contained no recognizable symbols."
Regardless of the plugin, the message is the same.
Anyone have any ideas or suggestions?
Last edited by sinisterbrain on Tue May 29, 2012 9:03 pm, edited 2 times in total.
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Kubuntu 12, no plugins work.
You are missing some 32bit libs I would think.
These are the 32bit libs AS accesses while running on my 64bit Xubuntu 12.4:
cheers
afx
Code: Select all
libc6:i386:
libexpat1:i386:
libfontconfig1:i386:
libfreetype6:i386:
libgcc1:i386:
libx11-6:i386:
libxau6:i386:
libxcb1:i386:
libxcursor1:i386:
libxdmcp6:i386:
libxext6:i386:
libxfixes3:i386:
libxi6:i386:
libxrandr2:i386:
libxrender1:i386:
zlib1g:i386:afx
sinisterbrain
- ram: 32Gb
I couldn't find packages for all the librararies you specified so I checked ldd output to see if I was missing any libraries. I can only find one "not found" library.
What's weird is:
It remains that way even after a manual ldconfig.
AS still operates properly, except when it comes to downloading 3rd party plugins. :-\
Output Here: http://paste.ubuntu.com/1012649/
Code: Select all
libtcmalloc_minimal.so.0 => not foundCode: Select all
$ ls -l /usr/lib/libtcmalloc_minimal.so.0*
lrwxrwxrwx 1 root root 28 Feb 19 10:57 /usr/lib/libtcmalloc_minimal.so.0 -> libtcmalloc_minimal.so.0.1.0
-rw-r--r-- 1 root root 138384 Feb 19 10:57 /usr/lib/libtcmalloc_minimal.so.0.1.0AS still operates properly, except when it comes to downloading 3rd party plugins. :-\
Code: Select all
$ ldd /opt/AfterShotPro/bin/AfterShotPro `find /opt/AfterShotPro/lib/ /home/mhenry/.AfterShotPro/ -type f -name '*.so*'`-
afx
- System_Drive: N/A
I did specify what dpkg told me (after searching referenced libs in a running AS with lsof), these are packages, not libs.sinisterbrain wrote:I couldn't find packages for all the librararies
Well, in your uploaded example only zText is shown and that seems broken. I do get the libs needed shown when using ldd on zText on my box.I checked ldd output
Nothing weird about that, this is a 64bit lib.What's weird is:Code: Select all
$ ls -l /usr/lib/libtcmalloc_minimal.so.0* lrwxrwxrwx 1 root root 28 Feb 19 10:57 /usr/lib/libtcmalloc_minimal.so.0 -> libtcmalloc_minimal.so.0.1.0 -rw-r--r-- 1 root root 138384 Feb 19 10:57 /usr/lib/libtcmalloc_minimal.so.0.1.0
You need 32bit libs.
And that lib is shipped with AS:
/opt/AfterShotPro/lib/libtcmalloc_minimal.so.0
When using LDD to check, you have to make sure your LD_LIBRARY_PATH is set appropriately.
(See the shell script /usr/bin/AfterShotPro
cheers
afx
sinisterbrain
- ram: 32Gb
Re: Kubuntu 12, no 3rd party plugins work.
I removed all the plugins as well as re-installed AfterShot to troubleshoot. Why bother adding complexity where it's not needed.
lsof | grep AfterShot output:
https://as-logger1.private.phx1.mozilla.com
Code: Select all
36680.573: Loading plugins
36680.575: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/asGPS.afplugin"
36680.575: "Plugin library contained no recognizable symbols."
36680.575:
36680.575: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/Bez.afplugin"
36680.575:
36680.576: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/CAQuest.afplugin"
36680.576: "Plugin library contained no recognizable symbols."
36680.576:
36680.576: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/FatToni.afplugin"
36680.576:
36680.577: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/Grain.afplugin"
36680.577: "Plugin library contained no recognizable symbols."
36680.577:
36680.578: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/Mix3.afplugin"
36680.578: "Plugin library contained no recognizable symbols."
36680.578:
36680.578: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/Nostalgia.afplugin"
36680.578:
36680.579: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/Nuance.afplugin"
36680.579: "Plugin library contained no recognizable symbols."
36680.579:
36680.579: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/Silicon Bonk.afplugin"
36680.579:
36680.580: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/Wavelet Denoise.afplugin"
36680.580: "Plugin library contained no recognizable symbols."
36680.580:
36680.580: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/Wavelet Sharpen3.afplugin"
36680.580:
36680.581: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/zChannelMixer.afplugin"
36680.581: "Plugin library contained no recognizable symbols."
36680.581:
36680.581: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/zFrame.afplugin"
36680.581:
36680.582: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/zPerspector.afplugin"
36680.582: "Plugin library contained no recognizable symbols."
36680.582:
36680.582: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/zShadow.afplugin"
36680.582:
36680.582: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/zSoften.afplugin"
36680.582:
36680.583: "Error loading plugin: /home/mhenry/.AfterShotPro/Plugins/zText.afplugin"
36680.583: "Plugin library contained no recognizable symbols."
36680.583:
spoilerhead
- System_Drive: N/A
- Hard_Drive_Capacity: 13.5TB
this sounds like some serious corruption.
try to:
- perform a file on one of the .so files in the plugin folder
- check access rights
ldd is quite pointless, you need to prepend the library path provided by ASP
Code: Select all
LD_LIBRARY_PATH=/opt/AfterShotPro/lib ldd libFatToniPlugin.so my ASP Plugins - donation button ( send beer!
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
sinisterbrain
- ram: 32Gb
I'm dealing with a very fresh install of Kubuntu 12. As in Friday evening, fresh. Aftershot appears to be running fine aside from 3rd party plugins (and my subjective opinion of UI changes). No other odd system behaviour aside from AS not wanting to load 3rd party plugins. I'll redownload all of them and see if they work.
$ find /home/mhenry/.AfterShotPro/ -type f -name '*.so*' -ls -exec file '{}' \;
$ LD_LIBRARY_PATH=/opt/AfterShotPro/lib ldd /home/mhenry/.AfterShotPro/Plugins/FatToni.afplugin/lib/libFatToniPlugin.so
What else can I be looking at?
Code: Select all
40108234 648 -rw-rw-r-- 1 mhenry mhenry 659795 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/Bez.afplugin/lib/libBez.so.1.0.0
/home/mhenry/.AfterShotPro/Plugins/Bez.afplugin/lib/libBez.so.1.0.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=0x75b0cf0e476219969afc3eaf1b216c664cfc5abc, not stripped
40108274 436 -rw-rw-r-- 1 mhenry mhenry 446012 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/CAQuest.afplugin/lib/libCAQuest.so.2.0.2
/home/mhenry/.AfterShotPro/Plugins/CAQuest.afplugin/lib/libCAQuest.so.2.0.2: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=0x7299b5404f8c551bb5a817531cd0f7c2c5f216ab, not stripped
40108283 320 -rw-rw-r-- 1 mhenry mhenry 324042 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/FatToni.afplugin/lib/libFatToniPlugin.so
/home/mhenry/.AfterShotPro/Plugins/FatToni.afplugin/lib/libFatToniPlugin.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=0x6d40a090cba307dc32bf6dcf6565ba976a3a784b, not stripped
40108347 364 -rw-rw-r-- 1 mhenry mhenry 368998 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/Nostalgia.afplugin/lib/libNostalgia.so.1.0.0
/home/mhenry/.AfterShotPro/Plugins/Nostalgia.afplugin/lib/libNostalgia.so.1.0.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=0xda93bb0bc94de34a4d93976f33fa0afae35fa055, not stripped
40108199 144 -rw-rw-r-- 1 mhenry mhenry 146760 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/zText.afplugin/lib/libzText.so
/home/mhenry/.AfterShotPro/Plugins/zText.afplugin/lib/libzText.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
40108452 108 -rw-rw-r-- 1 mhenry mhenry 109672 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/zShadow.afplugin/lib/libzShadow.so
/home/mhenry/.AfterShotPro/Plugins/zShadow.afplugin/lib/libzShadow.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
40108357 148 -rw-rw-r-- 1 mhenry mhenry 149853 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/Nuance.afplugin/lib/libNuance.so.1.0.0
/home/mhenry/.AfterShotPro/Plugins/Nuance.afplugin/lib/libNuance.so.1.0.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=0x45bd826f45a176bd71128e81aeea223fafcdca19, not stripped
40108396 380 -rw-rw-r-- 1 mhenry mhenry 385207 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/Wavelet\ Sharpen3.afplugin/lib/libSharpenPlugin.so.0.1.0
/home/mhenry/.AfterShotPro/Plugins/Wavelet Sharpen3.afplugin/lib/libSharpenPlugin.so.0.1.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=0x83a24a371dd6017686990e7ac36a5795e0569d14, not stripped
40108462 96 -rw-rw-r-- 1 mhenry mhenry 96928 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/zSoften.afplugin/lib/libzSoften.so
/home/mhenry/.AfterShotPro/Plugins/zSoften.afplugin/lib/libzSoften.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
40108428 396 -rw-rw-r-- 1 mhenry mhenry 404144 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/zFrame.afplugin/lib/libzFrame.so
/home/mhenry/.AfterShotPro/Plugins/zFrame.afplugin/lib/libzFrame.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
40108381 344 -rw-rw-r-- 1 mhenry mhenry 350288 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/Wavelet\ Denoise.afplugin/lib/libDenoisePlugin.so
/home/mhenry/.AfterShotPro/Plugins/Wavelet Denoise.afplugin/lib/libDenoisePlugin.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=0x10429ebdd26226dbe65cc5071929469aff6492ca, not stripped
40108299 324 -rw-rw-r-- 1 mhenry mhenry 330982 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/Grain.afplugin/lib/libGrainPlugin.so
/home/mhenry/.AfterShotPro/Plugins/Grain.afplugin/lib/libGrainPlugin.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=0x397a73883e6c8420bd8795cd9e131065aac163c8, not stripped
40108443 88 -rw-rw-r-- 1 mhenry mhenry 88836 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/zPerspector.afplugin/lib/libzPerspector.so
/home/mhenry/.AfterShotPro/Plugins/zPerspector.afplugin/lib/libzPerspector.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
40108365 320 -rw-rw-r-- 1 mhenry mhenry 324286 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/Silicon\ Bonk.afplugin/lib/libSiliconBonkPlugin.so
/home/mhenry/.AfterShotPro/Plugins/Silicon Bonk.afplugin/lib/libSiliconBonkPlugin.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=0x84c4c565e388ebba7a47217e1edff317e691ed01, not stripped
40108411 64 -rw-rw-r-- 1 mhenry mhenry 64096 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/zChannelMixer.afplugin/lib/libzChannelMixer.so
/home/mhenry/.AfterShotPro/Plugins/zChannelMixer.afplugin/lib/libzChannelMixer.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
40108311 88 -rw-rw-r-- 1 mhenry mhenry 89249 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/Mix3.afplugin/lib/libMix3.so.1.0.0
/home/mhenry/.AfterShotPro/Plugins/Mix3.afplugin/lib/libMix3.so.1.0.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=0x1fa7afd567b8a65f25b20c54bdee59dfa5abc6c3, not stripped
40108211 232 -rw-rw-r-- 1 mhenry mhenry 236252 May 28 23:23 /home/mhenry/.AfterShotPro/Plugins/asGPS.afplugin/lib/libasGPS.so
/home/mhenry/.AfterShotPro/Plugins/asGPS.afplugin/lib/libasGPS.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=0x00987e77789223efa7d53afc3ebb6a07ac0a081a, strippedCode: Select all
not a dynamic executable-
sinisterbrain
- ram: 32Gb
Figured it out. I had /home mounted as noexec.
Assumed that I didn't execute anything from my home folder, because I don't. I didn't think about applications loading dynamic libraries.
User error, will change the title of the post.
Code: Select all
sudo mount -o remount,exec /home User error, will change the title of the post.
