I regularly import files directly from DVD-R finalized with no problems - usual recored at either SP or XP mode - and the files being imported into VS x4 Pro check out fine - no issues with quality,sound,image,etc. Same as the originals.
However, once I render them - everything goes worse.
I make sure that the field is the same as the original,the FPS stay the same,and keep the files in 4:3 - But regardless of using original bit rate or changing the bit rate (Higher or Lower) as an Mpeg2 it comes out "Fuzzy"/"Dupey"/"Digital Artifacty" for a lack of a better word. As if something isn't being sampled or encoded properly when rendered. It's like a loss in quality that shouldn't be occurring when rendered,especially when it's the same bit-rate as the original. The complete files are showing the right properties but are not right.
I have both patches installed as well.
I've viewed these files with a couple of different media players and they look the same, and even on another computer. But Just WHAT is causing these problems.
I Love the VS products but this is really making me unhappy!
(Another situation happens when trying to make an AVI file where it doesn't convert properly and it has that "Venetian blinds" effect but this may be separate from the other problem)
