[solved] How to actualize the catalogs ?
wen452
System_Drive: H
Post by wen452 »
(sorry for the language mistakes, but I'm french)
Hello,
I'm trying Aftershot to quickly decide to buy it or not (to take advantage of the until May 27 offer).
I ask myself a question :
I imported my photo-library, so far so good. But the fact is that I often add or delete photos. If I delete one, the catalog more or less takes it into account by putting a "?" on the thumbnail, but if I add one, I do not see it in my catalog, even if I restart the software. Maybe there is a manipulation to update it?
(Seeing how hard it is to just contact Corel, easily, by mail, isn't really encouraging to buy their products...)
wen
sauron
operating_system: Linux
System_Drive: X
motherboard: Asus P5E WS Pro
processor: Intel Core2 Duo E6850
ram: 4GB
Video Card: ATI Radeon X850XT
sound_card: on board
Hard_Drive_Capacity: 5Tb
Monitor/Display Make & Model: NEC Multisync 2190UXi
Re: How to actualize the catalogs ?
Post by sauron »
The catalogue is just a small database that references the image files you've imported. As you've mentioned, if you delete a physical image outside Aftershot, then you'll see the thumbnail flagged, which is Aftershot's way of telling you it can no longer find the corresponding file. If you add images, they will not be in the catalogue database unless you import them - but you can easily just import a whole tree again, as ASP will no create duplicate records for things it already knows about.
So, just re-import the directories where you've added photos, and they'll be added to your catalogue.
wen452
System_Drive: H
Post by wen452 »
thanks, for the answer :D
and by re-importing all (more than 1000 photos), I won't lose all the tags I had added on the ancient ones ?
And if I open a new picture, tag it and save it in my database, will ASP, when I'll import the whole database again, takes into count those tags ?
thanks !
kaymann
motherboard: ASUS P8P67 PRO REV 3.1
processor: Intel i-7 6800K
ram: 32 GB
Video Card: NVidia GeForce RTX 2060
sound_card: Onboard
Hard_Drive_Capacity: 3.5 T
Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Post by kaymann »
Your tags will be fine just go ahead and reimport.
wen452
System_Drive: H
Post by wen452 »
Thank you very much for your quick and usefull answer.
I tried it with a new file and it worked just fine ;)
I'll buy the sofyware immediately and so benefit the promotion ;)
