clifford wrote:thanks for that tip.
im considering renaming my files as you stated earlier with your suggested date format.
however do you know any program on linux where i can do this in batches as i have a lot of raws. also, will i also have to rename every individual xmp file to match it for aftershot? could be long a tedious.
in fact do you recommend any program to batch rename on import from the card? etc?
cheers
I use ASP to rename, create a backup and import, all in one download queue. Then I ran a custom script that uses md5 to check that files are identical on my computer and on the backup server and write-protects image files; later I verify that the imported files are not corrupted by looking at them in ASP; and only at that point I remove the images from the memory card.
You should never remove images from you memory card before having made at least two copies of them; but I guess you learned that.
If you prefer to use an external tool and don't feel like writing your own scripts, you can try Rapid photo downloader
http://www.damonlynch.net/rapid/, which I used while Bibble5 was
waaaay too much unstable.
If you want to rename raw and xmp files, it's just a one-liner of shell script; but that may not be sufficient since the file name appears also in some xmp field. Why don't you just use ASP to rename files? since you have a back-up, it'd be pretty easy to verify that the renaming is correct.
In any case: why do you want to rename old files? Just leave them alone, just be sure that your new naming scheme will never conflict with whatever you have now.
Ottavio
