Ive just recieved my new Video studio pro X5 Ultimate I already have Video studio pro X4 Ultimate installed!
I have seen various members stating problems with installing X5 With X4 installed!
What should i look for or do??
What should i back up before attempting do do this?
Should i just uninstall X4 first? (I shouldn't need it after X5 is installed)
Some addons will not install etc what is the procedure?
Pete
Installing X5 pro Ultimate
Pete Waterman
- processor: Intel Core i7 7700
- ram: 12gb
- Video Card: AMD Radeo R5 435
- sound_card: Realtek alc888s-VD Audio
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: Samsung
- Corel programs: Video Studio Ultimate 2019, 2021, 2023
I know that you believe you understand what you think I said,
but I'm not sure you realize that what you heard is not what I meant.
Re: Installing X5 pro Ultimate
whenever I get a new version of VideoStudio I just install it - never do anything with the previous versions - never un-install them - I have had four different versions on one computer all working perfectly.
I have never had a problem of any sort when installing a new version when older versions are also present.
Pete Waterman
- ram: 12gb
Thank Brian
Ive installed itRegisterd it & had a confirmation e-mail that tell me to use the download link to download NewBlue TitlerEX umm Can anyone tell me where it is?
the link gets redirected to http://www.corel.com/corel/category.jsp ... toreKey=us
this is a "regincentive" um yes ok then!
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
VS X5 will install on a separate folder and will not affect the old version, so you can keep multiple version of videostudio on one computer. I actually have 5 versions on my home computer.Pete Waterman wrote:Ive just recieved my new Video studio pro X5 Ultimate I already have Video studio pro X4 Ultimate installed!
Pete
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
teknisyan
- ram: 4 GB
It appears that you are referring to the registry incentive.. you should have the download link in an email that will be sent to the email address that you use to register your VS X5.Pete Waterman wrote:Thank Brian
Like reading blogs?
About Tech
About Sports
About Tech
About Sports
Pete Waterman
- ram: 12gb
Thanks for the reply I have it sorted now,and yes It was the Register incentive the link would not work correctly it kept redirecting me to http://www.corel.com/corel/category.jsp ... toreKey=usAbiel Corel NA wrote: It appears that you are referring to the registry incentive.. you should have the download link in an email that will be sent to the email address that you use to register your VS X5.
I got a link from Corel that worked, Its funny really it was the same link?? I tried my e-mail link after & that then worked??
As far as the install goes yes all installed and seems fine I haven't tried it all yet but all the add-ons are there!
Thanks again for the advice, & the reassurance
Pete
roykarin
- motherboard: Gigabyte X38-DQ6
- processor: Intel Core2 Duo 2.33GHz
- ram: 4Gb
- Hard_Drive_Capacity: 2000Gb
- Monitor/Display Make & Model: 22" Chimei
I installed X5 Ultimate a few days ago. I still have X4 on my computer and I had no problems with installing X5. However I'm disappointed with X5. I made a videoslide show which lasted 29 minutes and was 1.9Gb. It took 4hours, 15minutes and 8 seconds to burn a DVD!!! I might go back to X4!
roykarin
roykarin
Did you first produce a DVD-compatible mpeg-2 of your slideshow before going into the burning module? And did you use any of the more complicated menu options once you were in the burning module?
roykarin
- ram: 4Gb
I went into 'share' and went throught the nornmal procedure I have used in X4, ie, select DVD and then go through to the last section to burn the DVD,. I don't use anything in the 'complicated' edit section. I don't know how to convert to mpeg 2, so I didn't do that? I will be re doing the slideshow in X4 today if I get a chance, so it will be intersting to see how long it takes to burn a DVD?
roykarin
roykarin
