Howto resize "Presets" widget
lundbech
- System_Drive: N/A
- motherboard: HAL 9000
I put the presets on a tab for itself. I have quite a few presets, so I'm kinda fed up with scrolling the list.
Is there any way you can resize the "Presets" dialog so it fits the whole height of the tab?
(Solution in post no. 7 in thread.)
jpmccormac
Re: Presets on a Tab for Itself
How do you do this? I find the Tabs menus very confusing. Is there a way to simplify or rename tabs?lundbech wrote:I put the presets on a tab for itself.
"All who wander are not lost."
afx
- System_Drive: N/A
- Video Card: FirePro 4900
You could try to hack the UI file for the presets...lundbech wrote:Is there any way you can resize the "Presets" dialog so it fits the whole height of the tab?
The customToolsUI.txt UI hack to change the tool tabs still works, see http://flightofthebibbles.blogspot.com/ ... -tabs.html and http://forum.corel.com/EN/viewtopic.php?f=90&t=45735jpmccormac wrote:I find the Tabs menus very confusing. Is there a way to simplify or rename tabs?
cheers
afx
lundbech
- System_Drive: N/A
Tried that. Added this (this used to work in Bibble):afx wrote:You could try to hack the UI file for the presets...lundbech wrote:Is there any way you can resize the "Presets" dialog so it fits the whole height of the tab?
Code: Select all
<property name="minimumSize" >
<size>
<width>0</width>
<height>640</height>
</size>
</property>/opt/AfterShotPro/supportfiles/tools/Presets.ui
right before <property name="sizePolicy">
and it does resize the Presets widget, but not the scrollbox with folders inside it. It remains the same size, centered inside a much larger Presets widget. Any thoughts?
afx
- System_Drive: N/A
Nope, sorry, no time to fiddle with the Qt widget hierarchies at the moment ;-(lundbech wrote: Any thoughts?
cheers
afx
kaymann
- motherboard: ASUS P8P67 PRO REV 3.1
- processor: Intel i-7 6800K
- ram: 32 GB
- Video Card: NVidia GeForce RTX 2060
- sound_card: Onboard
- Hard_Drive_Capacity: 3.5 T
- Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
- Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Re: Resize "Presets"
Put the Presets UI into it's own tab and tried all the above still no go. Time for Monkey
2012-5-12
Catalog corruption was causing the ASP crash not the edits above.
Thanks looks beautiful now!
2012-5-12
lundbech
- System_Drive: N/A
Since no one wanted to do the job for me, I had to find out for myself.kaymann wrote:Put the Presets UI into it's own tab and tried all the above still no go. Time for Monkey
So this is how it works.
Edit the Presets.ui file.
Found here om Linux: /opt/AfterShotPro/supportfiles/tools/Presets.ui
Insert this code:
Code: Select all
<size>
<width>0</width>
</size>
</property>
Code: Select all
<property name="sizePolicy">So find this line
Code: Select all
<widget class="CPresetsWidget" name="Presets" native="true" />Code: Select all
<widget class="CPresetsWidget" name="Presets" native="true">
<size>
<width>0</width>
</size>
</property>
</widget>
Code: Select all
<?xml version="1.0" encoding="UTF-8"?>
<ui version="4.0" >
<class>BibbleSettingsForm_bis</class>
<widget class="SettingsWidget" name="BibbleSettingsForm_bis" >
<property name="geometry" >
<rect>
<x>0</x>
<y>0</y>
<width>303</width>
<height>209</height>
</rect>
</property>
<size>
<width>0</width>
</size>
</property>
<sizepolicy hsizetype="Preferred" vsizetype="Preferred">
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
</property>
<property name="windowTitle" >
<string>Presets</string>
</property>
<layout class="QVBoxLayout" name="verticalLayout" >
<property name="margin" >
<number>0</number>
</property>
<item>
<size>
<width>0</width>
</size>
</property>
</widget>
</item>
</layout>
</widget>
<customwidgets>
<customwidget>
<class>SettingsWidget</class>
<extends>QWidget</extends>
<header>SettingsWidget.h</header>
<container>1</container>
</customwidget>
<customwidget>
<class>CPresetsWidget</class>
<header>PresetsWidget.h</header>
</customwidget>
</customwidgets>
<resources/>
<connections/>
</ui>
This should probably be moved to the "Tips, Tricks, and Results" subforum.
Hobgoblin
- System_Drive: N/A
Re: Howto resize "Presets" widget
Many thanks.
That works fine.
Worth remembering that at an upgrade this will almost certainly be overwritten - so make a copy and keep it somewhere safe!
R.
That works fine.
R.
AsterixEtObelix
- System_Drive: N/A
- motherboard: Debian squeeze 64
- processor: Intel
Thanks for the tips ! the Preset ui is more usable now
Ianr
- Monitor/Display Make & Model: Dell 30
Cool, thanks for that info .....
nyukuri
- ram: 4GB
- Hard_Drive_Capacity: 500GB
Resize "Batch Output"
that so cool, thank you, my preset list is now so much better and of course has its own tab
BUT I have also many Output batches and the window for them is too small, I was looking for an .UI but didn't find any for the Batch Output. Does anyone have an idea on how to change the size of the Batch output tab?
Thank you in advance and greetz from the heart of Africa!
nyukuri
nyukuri
lundbech
- System_Drive: N/A
Re: Resize "Batch Output"
I did look for that one also, but didn't find it. Even looked through the complete list of installed files, to see if there was something obvious there, but no such luck ...nyukuri wrote:that so cool, thank you, my preset list is now so much better and of course has its own tab
nyukuri
- ram: 4GB
resizing tabs on LEFT panel
I was looking up the registry and found the info concerning the Output tab:
HKEY_CURRENT_USER\Software\Corel\AfterShot Pro\LastRun\QueueToolBox\Output\batch_output_dwidget
there one can save if the tab is pinned or not, and Aftershot DOES respect the change on start up.
interestingly, there is also an entry for the SIZE:
PinnedSize=@Size(214 228)
But if I change this to @Size(214 428) AfterShot Pro does NOT accept the change and resets the value when it is started. I tried different values and all different tabs (Batch Output, Catalog etc.) No success!
So it seems there is really no way of changing the size of the tabs on the left panel...
regards,
nyukuri
regards,
nyukuri
Can anybody point me at where the Presets.ui file resides on Mac OS?
Maybe I'm just too blind to see it. Most other adjustments I have done so far could be made in ~/Library/Application Support/Aftershot Pro
Thanks and best regards
