Image of post-it + pin=> How could I change the pin color?
cadudesun
Post by cadudesun »
Hi, the image is attached.
I would like to make the pin "blue", without loosing "real" appearance.
Advance thanks for help!
wds937
motherboard: Dell 0HN7XN A01
processor: Intel Pentium Dual Core E5800 - 64-bit - 3.20 GHz
ram: 4 GB
Video Card: Intel G41 Express - integrated
sound_card: Realtek High Definition Audio - integrated
Hard_Drive_Capacity: 320 GB
Monitor/Display Make & Model: ASUS VS247
Re: Image of post-it + pin=> How could I change the pin colo
Post by wds937 »
Quick and dirty way:
  • Click on the desired blue color in the Materials palette
  • Click the Color Changer tool (on the same button as the Flood Fill tool)
  • Click the red push pin in the image
You may have to click more than once to completely replace the red color.
It may require some trial-and-error with regard to the Tolerance and Edge Softness settings for the Color Changer tool, and some experimentation with the particular color. I did a sky blue in less than a minute.
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
You could also use an adjustment layer. Click Layers> New Adjustment Layer> Hue/Saturation/Lightness, when the dialog box comes up make sure the Preview On Image is checked and have at it. Moving the Hue slider first will give you the color, then adjust the Saturation slider.
Of course, this would work well with this image since only the pin is colored. If you have alot of other colors you'd need to mask off what you didn't want affected, but you get the idea.
Regards, Dan
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
I think in this particular image df's suggestion worked the best. But you've got to love that there are so many options.
Another way would be to create a new layer put a blob of color on top of the pin, then change the blend mode to get different results. Adjust the opacity until you find something you like. Then you can use the Adjust->Colorize command to quickly change the color of this new layer if you wanted to try a new one.
Or if you trusted yourself to paint it in you could use the "Change To Target" brush. This fun brush allows you to pick a color and then apply either the color itself, just the saturation, just the hue, or just the lightness, to an image while keeping most of the original texture. It's not as automated as the Color Changer tool but since this peg is essentially round using a brush should not be that difficult for it.
cadudesun
Post by cadudesun »
Thanks everybody!!!
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Post by Cassel »
Another way that might work well in this case is using the Adjust > Hue and Saturation > Hue Map.
There, move the slider for the red color to the blue level. You can do it also with orange. Since the rest of your image does not have colors, it should change only the pin color.
Cassel
https://scrapbookcampus.com
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
You can use the COLOR CHANGER TOOL, you can try this short tutorial that I created sometime ago, even though I used PSP X2 Ultimate.
http://abielonline.blogspot.com/2009/04 ... using.html
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
