Previously in Bibble, when I was sorting picture (pick, reject) I used to set a filter on the current folder : flag does not equal reject.
Then I was browsing (in image view or standard view) my pictures and tagging on the fly "rejected" / "picked" just using the keybord shortcuts.
Now in ASP it isn't possible anymore. I mean not so easily. Because when I reject a flag, the picture disappears instantly and I can't move to the next picture except if I use the mouse. Worse, if I was using the image view, I have to click first on standard view or thumbnail view to select a new Image. So I have to unset the filter. That is OK for a single pass sorting. But if you need several pass, it is very usefull to hide rejected pictures.
It was more convenient on bibble. That would be great if the filter get back the Bibble's filter behaviour.
[solved] bibble's filter behaviour
Darktable 3. Bye bye aftershot.
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: bibble's filter behaviour
Have a close look at the filter dialog.
There is a new checkbox.
cheers
afx
cheers
afx
