I can't remove keyboard shortcuts from the keyword manager. Is that normal ?
EDIT : I mean, I click on the X witch empty the field, then I click on the notch and then the old shortcut re-appears...
[SOLVED BUT BUG] keyboard shortcuts and keywords manager
Darktable 3. Bye bye aftershot.
Re: keyboard shortcuts and keyword manage
i would suggest you check the own-settings of the file "hotkeys.xml".
xubuntu has it in /home/[user]/.AfterShotPro
fedora.. i dont know. =)
Bibble since 2004. Aftershot until 2020. From then on darktable.
@grunbernd : the path is the same whatever linux distros.
I searched a bit and I noticed that keyboards short-cuts for Keywords-sets are defined in two different places :
What I did, is editing the xml file to set my short-cuts. Then I started ASP et checked in the keyboard part of the main settings if everything was OK.
It is fixed, but I still think there are some kind of bugs behind this.
- in the keyword manager
- in the keyboard part of the ASP main settings
