Problem creating a DVD from HD FILE
KOBRA76
motherboard: Gigabyte
processor: 3.07 gigahertz Intel Pentium Dual-Core
ram: 2 GB DDR3
sound_card: VIA High Definition Audio
Hard_Drive_Capacity: 500GB
Post by KOBRA76 »
I edit files in HD on PRO X4 and when I want to burn project to DVD The software crashes , what am I not doing right?, and another question, I want when I watch on DVD There is two black stripes on the screen up and down.How do I make it disappear?
Canon 550D,18-55 & 50mm Lenses
My You Tube Channel
http://www.youtube.com/user/HDMAN2012?feature=mhee
Re: Problem creating a DVD from HD FILE
It just happens that yesterday I converted a HD file to DVD, and it went well. The DVD also fills my entire HDTV screen. What I always do, though, is first convert the HD file to an SD DVD (mpeg-2) file. If the project is under one hour in length, then use the full default 8000 kbps as the bitrate, and of course make sure it is set to 16:9 and Upper Frame First.
Once I have the new file, I then go to the burning module and insert it there manually. I first close the project in the editing module to make sure the project file -- as opposed to the new mpeg-2 file -- is NOT inserted in the burning module. Then I check to make sure that in the Options icon in the bottom left of the burning screen the box beside "Do not convert compliant MPEG files" is ticked. I then build a menu if I want one (yesterday, I didn't), and then burn.
KOBRA76
ram: 2 GB DDR3
Post by KOBRA76 »
THANKS I WILL TRY TO DO LIKE YOU SAY
My You Tube Channel
KOBRA76
ram: 2 GB DDR3
Post by KOBRA76 »
I did not get the movie on the screen at full size, and did the steps you explained
My You Tube Channel
