Heat Haze effect
naw717
- processor: Intel[R] Core[TM] i5-6300HQ CPU 2.30GHz
- ram: 8 GB
- Hard_Drive_Capacity: 225 GB SSD
- Corel programs: VideoStudio X9
Heat Haze effect
Hi all. I am using VideoStudio Pro X4, and I am looking to add the "heat haze" effect to a video I am working on. Does anyone have any suggestions on how to do this? Thanks.
Re: Heat Haze effect
Not sure of the exact effect you are hoping to achieve - but you can get a varying diffuse effect by applying the "average" filter to your video (from the "FX" library - then using customise filter to add key frames and change the cell size at each one so that the image hazes and clears as you want.
If that is not what you were after then try applying two or more filters to your video and customising them and get the desired effect.
Kingston
- motherboard: Gateway [Acer] DX4860
- processor: Intel Core i5 3rd gen. 3 GHz
- ram: 8 GB
- Video Card: Intel HD 2500
- sound_card: Bluetooth
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Upgrading to X5 Ultimate might be in your future. That has some of the NewBlueFX Motion Effects, such as Rolling Wave. Two of the presets are "Mirage" and "Heat Rising."
