Filter weirdness
Bugs & Suggestions
myro
Filter weirdness
Post by myro »
my workflow consists of two steps: Going through a batch of photos and mark these which I want to work on.
Then I filter to all marked images and start working on them. Part of this work is giving stars. Most of the time, this works quit good. But with version 1.0.1.10 I found that *sometimes* a photo is removed by the filter when it gets stars: Just as stars are given, the photo is removed from preview. I then had to disable filter, search for the photo, remove mark and stars, set mark and stars again and reenable filter - photo is back again.
This is already a bad thing, but it gets worse when I wish to send all filtered images to a output batch: Ctrl-A and drag them to the batch - some images are just left out.
As this is absolutly new in 1.0.1.10 - and I'm using bibble for quite some time now - I really hope for a quick solution.
(ASP 1.0.1 running on W7 Pro)
Best regards
Klaus
Application vers.: 1.0.1.10
Product Name: AfterShot Pro Registered
Built on: So Apr 1 2012
Platform: Windows
Language: de
App Path: C:/Program Files (x86)/Corel/Corel AfterShot Pro/build/AfterShotPro.exe
System Home: C:/Program Files (x86)/Corel/Corel AfterShot Pro/supportfiles
User Home: C:/Users/Klaus/AppData/Local/Corel/AfterShot Pro
Prefs Home: \HKEY_CURRENT_USER\Software\Corel\AfterShot Pro
Processors: 2
CPU Threads: 2
I/O Threads: 1
B. In-flight: 1
RAM: 6143 MB
SIMD Version: SSE2
Build Mode: Release
Proc. speed: 2.4 GHz
OS Name: Microsoft Windows 7 Service Pack 1
OS Version: 6.1 (Build 7601)
System arch: x64
Memory used: 72%
==================== Plugins =====================
Name:
Identifier:
Version: 1.0.0
Path:
Identifier: sph.SiliconBonk
Version: 0.31.0
Path: <User Home>/Plugins/Silicon Bonk.afplugin
Identifier: com.corel.vigne
Version: 1.1.0
Path: <User Home>/Plugins/Vigne.afplugin
Identifier: sph.waveletdenoise
Version: 0.31.0
Path: <User Home>/Plugins/Wavelet Denoise.afplugin
Identifier: sph.waveletsharpen
Version: 1.34.0
Path: <User Home>/Plugins/Wavelet Sharpen3.afplugin
Name: Black and White
Identifier: com.corel.BlackAndWhite
Version: 1.0.0
Path: <System Home>/plugins/Black and White.afplugin
Identifier: com.corel.equalizer
Version: 1.0.5
Path: <System Home>/plugins/Equalizer.afplugin
Identifier: com.SMP.Nostalgia
Version: 1.0.8
Path: <System Home>/plugins/Nostalgia.afplugin
kaymann
motherboard: ASUS P8P67 PRO REV 3.1
processor: Intel i-7 6800K
ram: 32 GB
Video Card: NVidia GeForce RTX 2060
sound_card: Onboard
Hard_Drive_Capacity: 3.5 T
Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Re: Filter weirdness
Post by kaymann »
Are you sure you have "All conditions met" uncheck in your filter? Mine seems to wrok fine everytime... What are you using as the filter condition to mark rejects - the flags?
myro
Post by myro »
Thanks for the quick answer :)
Yes, met all conditions is checked, but only "Marked as green flag" is set.
As mentioned: That didn't happen to all pictures, just some of them - but I cannot say why...
grubernd
operating_system: Linux
System_Drive: N/A
Post by grubernd »
if this is the same issue i sometimes have: they dont disappear, they get sorted away.
workaround: flip the sort-by item back and forth and they should be in order again.
the god of bugs knows why, but it happens sometimes, not really often (here) and i havent been able to reproduce it consistently. which in turn makes it hard for the coders to find it. if you find a straight way to reproduce, please tell it to the monkey (see signature).
cheers,
grubernd
Bibble since 2004. Aftershot until 2020. From then on darktable.
