Can't apply color balance to selected area
GregReese
Post by GregReese »
I have PSPx4. If I select an area of the image and try to apply color balance (Adjust|Color balance), the effect gets applied to the entire image, not just the selected area. Is there a way to apply color balance to just a selected region?
Greg Reese
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Can't apply color balance to selected area
Post by LeviFiction »
That is weird. It also forces floating selections to merge back down.
So the only way I can think to do it is to Promote the selection to a new layer. Perform the adjustment, then merge back down.
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
It does the same thing in X2. But, if you use the tool called "Adjust Color Balance" that's found under "All Tools" in the Customize dialog, it only changes the selected portion of the image.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
GregReese
Post by GregReese »
LeviFiction wrote: So the only way I can think to do it is to Promote the selection to a new layer. Perform the adjustment, then merge back down.
Thanks LeviFiction, that worked well.
Greg Reese
ram: 6 GB
In X4 All Tools might have been replaced with "All commands" I don't know as I no longer have x2. But it's also found under "Unused Commands" as it was initially replaced with the Color Balance command.
Although very similar in input options the result is ever so slightly different.
I use them both for this reason. Especially the White Balance adjustment and Color Cast removal options. It always depends on the image, sometimes Color Cast Removal works better sometimes White Balance Adjustment. So I don't consider them replacements for each other.
But if it gets you the result you want, it's a lot easier than my method. ;)
LindaSue
ram: 3 GB
Post by LindaSue »
Slip of the fingers. I did mean "All Commands" not "All Tools".
