Every time I try to start up AfterShot Pro on my Windows 7 64 bit system, it dies immediately after the user interface is displayed. The event log shows the following:
Faulting application name: AfterShotPro.exe, version: 6.0.0.3, time stamp: 0x4f78b258
Faulting module name: KERNELBASE.dll, version: 6.1.7601.17651, time stamp: 0x4e211319
The last thing in the AfterShotPro.log is:
18284.968: "attempt to write a readonly database Unable to fetch row"
18284.974: viewmode: 1
It works if I run as administrator, but that shouldn't be necesseary, right?
Doug
Failure to Load on Windows 7 64 Bit (FIXED)
dolender
- motherboard: ASUS P8P67
- processor: Core i7 2600
- Video Card: NVIDIA GeForce GTX 560
- Hard_Drive_Capacity: 2.1 TB
- Monitor/Display Make & Model: Samsung P2770
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Failure to Load on Windows 7 64 Bit
Make sure you own and have write access to your AS user directory and the DB.dolender wrote:The last thing in the AfterShotPro.log is:
Looks like you ran it initially once as admin which created the files and now you can't write to them.
cheers
afx
dolender
Re: Failure to Load on Windows 7 64 Bit (FIXED!)
Hey thanks a lot man. That fixed it right up. When I installed it, I put the settings and catalogs on my second drive, which for some reason, Windows 7 had set up with special permissions for the Users group. I fixed that and it seems to work great now.
Thanks,
Doug
Thanks,
Doug
