I was trying to figure out a quick way to emulate the GIMP script "Vintage Look"
http://registry.gimp.org/node/1348
I used the bleach bypass as a starting point then emulated the Yellow/Magenta/Cyan layers with Sadman's Texa. Using Texa you can also adjust the tones of the 3 variables. I'll probably figure out a more elegant way of doing this soon but thought I'd share.
Example :
Vintage Look from GIMP Plugin Reg
- Attachments
- Vintage Look from GIMP.zip
- (2.31 KiB) Downloaded 374 times
Re: Vintage Look from GIMP Plugin Reg
Figured out a quick way with Fatoni & Basic Adjustments.
- Attachments
- Vintage Look without Texa.xmp
- (1.84 KiB) Downloaded 412 times
BitKeeper
- motherboard: P5B Delux
- processor: Intel Q8400
- ram: 4GB
- Video Card: Nvidia GTX 460
- Hard_Drive_Capacity: 11TB
- Monitor/Display Make & Model: Dell 24"
Have been playing trying to get a Vintage look also.
This is what I have so far.
Edward,
great results! Personally, I like - and often use - the "Kinemacolor"-Settings that Bernd Gruber posted ages ago for the Mathbox-Plugin.
http://grubernd.at/116/kinemakolor/
Also, have you tried tinkering with Nostalgia? One of the Polaroid (like "669 Hot") should come fairly close.
Beste Grüße von
Ingo
Beste Grüße von
Ingo
