After not having much luck with the last video card, I changed my video card to a device with the Philips 713x chipset
Now when I select video capture I get the following message:
failed to initialize the video capture plugin
Open driver failed
(15200:43:0)
(15023:4:2)
cannot create the video capture filter
I have just installed card (SAA7130 TV PCI card) with latest drivers excluding the software so Video Studio 12 pro is the only capture software on the machine
I also re-installed both card and Video Studio after doing a complete system restore and used CC cleaner to remove any residual data before re-installing
I need to use video capture within the Video Studio software as I need to use the scene detection functionality.
The reason I had to change the card in the first place is that video studio only allowed me to capture in AVI 320x240 and gave 'capture failed' errors with anything else.
Please help!
Video Studio x2 capture errors
MyMusicMatrix
- motherboard: Gigabyte hyperthreading
- processor: 3.1GB intel
- ram: 3Gb
- Video Card: SAA7130 TV card w Philips 713x chipset NVidia GC
- sound_card: two M-Audio delta 1010 LT
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Dell and LG
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Re: Video Studio x2 capture errors
YOur problem is capture cards are designed to work with their own software, the only advice I can give is to install that, use it to capture and then do your editing manually.
