This is just absolutely frustrating. No one from customer help will help me. So I am hoping someone here can. For some reason I can NOT write a script that will work in any other version accept for X4. As far as I can figure it comes down to one command that comes up that no other version of PSP recognizes. It happens when I go to the different layers to start the shading etc. Any help is appreciated. I have pasted the command that appears below. Thanks in advance! ANd I'm not even working with vector layers, they are ALL raster layers lol
# Vector Selection Update
App.Do( Environment, 'VectorSelectionUpdate', {
'Path': (0,2,[],False),
'Type': App.Constants.ObjectSelection.Select,
'GeneralSettings': {
'ExecutionMode': App.Constants.ExecutionMode.Silent,
'AutoActionMode': App.Constants.AutoActionMode.Default,
'Version': ((14,0,0),1)
Sucessful Script Making in X4?
tattooedfreek77
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
Re: Sucessful Script Making in X4?
I have both X4 and X3 installed on this computer. I recorded a script in both to see how things are acting differently.
In X4 I get what you do:
But in X3 I get:
All I did to get the code was
Create a new image (blank)
Create a new layer on image
Select bottom layer
Start recording, select top layer, save recording.
I didn't do anything in either remotely related to a vector of any sort, at least not that I know of.
Code: Select all
'Path': (0,1,[],False),
})Code: Select all
# SelectLayer
App.Do( Environment, 'SelectLayer', {
'Version': ((13,0,0),1)
})Create a new image (blank)
Select bottom layer
Regards, Dan
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
This came about when X4 gained the ability to select multiple raster layers. All previous versions could only select one raster layer at a time. So essentially they just used the vector selection abilities to select raster layers. This has made it difficult for scripters. But as df's example shows you just need to use the right command for older versions.
So to make up for this you have to exchange the "VectorSelectionUpdate" method. Just change that to say "SelectLayer" instead. Should be fine.
