Hello,
Noise Ninja seems to be poorly implemented in ASP/Bibble. Color noise reduction leads to severe color shifts in the shadows. The algorithm seems to average between noise and image pixels; the result looks distincly reddish/greenish. Funnily, turning NN off and denoising the rendered jpg in ASP/Noise Ninja leads to much better results.
Wavelet Denoise is much better in this respect; the results are very grainy though - I prefer the smoothness of Noise Ninja. Am I the only one to see this?
Cheers
Frank
Noise Ninja
Fraenzken
- ram: 4 GB
- Monitor/Display Make & Model: IIyama ProLite E1900S
Noise Ninja
my photos: http://naturfotos.bplaced.net
larschristian
- System_Drive: N/A
- motherboard: ASUS something
- processor: AMD Phenom II X6 1090T Processor
- Video Card: ATI radeon something
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Dell 2312HM + Samsung SM913v
Re: Noise Ninja
Haven't noticed any such problem with NN. Using registered with Canon 600D.
Re: Noise Ninja
I'm not sure but I mean there was a NN BUG with some Cameras an dark parts of picture -> see some old posts in Bible 5 Forum.
Robert
Robert
Re: Noise Ninja
as RobiWan said..
so please tell us what camera you are using, provide an example if possible and even better submit that exact report to the surveymonkey.
Bibble since 2004. Aftershot until 2020. From then on darktable.
Fraenzken
- ram: 4 GB
Re: Noise Ninja
Here's a few examples (with the Olympus E-M5 and the Olympus E-620). The problem only becomes apparent when dialing up exposure (or lift the shadows). Which still is a bad thing because lifting the shadows makes the noise much more apparent, so noise reduction is important under these circumstances.
- Attachments
Fraenzken
- ram: 4 GB
Re: Noise Ninja
i only have a few OMD5 files scraped off the various review-sites and i dont see a problem with noise ninja.
for one: pumping up any file by 3 stops is really stretching ones luck and image quality, too. using Coarse Noise has to average among large areas, otherwise it wouldnt be effective. for example using large values in Wavelet Denoise changes colors, too, and not by a little. expected behaviour for me. comparing a RAW and a JPG is always difficult using a fixed pipeline software like ASP, since you cannot simply skip certain stages that do something with the data..
e.g. NoiseNinja runs very early in the pipeline and before you push that file up.. even the tiniest of colorshift will be exaggerated. by comparing that RAW to a JPG, where you basically just shift the NN from an early stage to the end, the difference is expected.
denoisers are pretty good these days, but they cant perform magic.
PS: i am pretty impressed by the new oly.. if it would not cost more than a nikon D7000 i would love to expand my µ43 system with it (currently only a pana G2).
Fraenzken
- ram: 4 GB
Re: Noise Ninja
... you're right, Bernd, it's not a very big deal. It can be annoying though.
Re: Noise Ninja
Hi Frank,
I get similar "bad" colors when I shoot in mRAW/sRAW with my EOS 60D ... even w/o NN ... but that´s off topic.
No, so far I could not observe these extreme color shifts with NN ... but would need to check if they are really not there. Maybe I´m a lucky guy or do not watch the results carefully enough !?
My experience with NN and WD is that on high ISO shots I get best results (regarding noise) when I apply NN + some WD (color only). On low & normal ISO (up to 800 ?) I apply only WD.
When I find some time I´ll create a thread about these results with the EOS 60D .... but I guess this doesn´t help you
BR
Markus
BR
Markus
OpenSuse 11.4 (32bit)
Dell U2410
Dell U2410
