Aftershot Pro Crashes if i delete Photos
Bugs & Suggestions
cluhn
operating_system: Linux
System_Drive: N/A
motherboard: Gigabyte GA-H67MA-UD2H
processor: Intel Core i5 2300
ram: 8096
Video Card: Intel HD2000
Hard_Drive_Capacity: 2500 GB
Monitor/Display Make & Model: Eizo EV2333
Post by cluhn »
If i delete Photos in the Catalog or in de Filesystem Aftershot Pro crashes every first or third photo.. It is really annoying.
I use Aftershot Pro Version 1.0.10 64-bit under Ubuntu Linux 11.10 (the last months) and since some days under 12.04.
The error exists since i use ASP. Are there any Logfiles that i can send to the developers that are usefull to analyse the Problem? Do someone know this Problem and can help me resolve it?
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Aftershot Pro Crashes if i delete Photos
Post by afx »
See if you can spot anything interesting in the AfterShotPro.log file in your AS user directory.
You might want to post the last 20 or so lines here. If that has nothing interesting, strace would be the next option.
cheers
afx
cluhn
System_Drive: N/A
ram: 8096
Post by cluhn »
there is not much to see in the logfile.. There are only the files that being "trashed" and then 75913.761: Nuance: HOTNESS CHANGE..
No one else seems to have this Problem. :/
strace ends with the output "--- SIGSEGV (Segmentation fault) @ 0 (0) ---"
afx
System_Drive: N/A
Post by afx »
Is the Nuance entry the last one before the segfault? Are you sing the latest version of Nuance?
cheers
afx
cluhn
System_Drive: N/A
ram: 8096
Post by cluhn »
So i disabled Nuance and deleted around 100 photos with no problems. But suddenly it crashes again while deleting a photo, from now on it is crashin every time i delete a photo. The aftershotpro.log says nothing.. Here is the output from strafe (removed my username):
Code: Select all
_llseek(49, 24, [24], SEEK_SET)         = 0
read(49, "\0\0m\7\0\0\0\0\0\0#\"\0\0\7W", 16) = 16
fcntl64(49, 0xd /* F_??? */, 0xffe12974) = 0
gettimeofday({1336308252, 76486}, NULL) = 0
stat64("/etc/localtime", {st_mode=S_IFREG|0644, st_size=2309, ...}) = 0
fcntl64(49, 0xd /* F_??? */, 0xffe12214) = 0
access("/home/user/Bilder/AfterShot Pro Catalogs/Eigener Katalog/base-journal", F_OK) = -1 ENOENT (No such file or directory)
fstat64(49, {st_mode=S_IFREG|0644, st_size=9340928, ...}) = 0
fcntl64(49, 0xd /* F_??? */, 0xffe121f4) = 0
Process 8899 detached
Maybe the "base-journal" is the problem? This do not exist..
afx
System_Drive: N/A
Post by afx »
The journal is only a temporary file...
But I suspect your catalog is hosed.
Best recreate it.
cheers
afx
photoalexis
motherboard: BioStar A780L3G
processor: AMD Phenom II
ram: 8gb
Video Card: VisionTek Radeon HD 5450
sound_card: on board
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: LaCie 321 & HP LA2205wg
Post by photoalexis »
I had the same problem, but i uninstalled ASP and re-installed it and it fixed the issue. The catalogs and all keywording was not affected.
cluhn
System_Drive: N/A
ram: 8096
Post by cluhn »
Hm.. i uninstalled ASP and recreated the catalog and i have the same error..
I deleted the configuration directory in my homedirectory and the configuration was still available after reinstallation. Where ASP stores the configuration?
afx
System_Drive: N/A
Post by afx »
cluhn wrote:I deleted the configuration directory in my homedirectory and the configuration was still available after reinstallation. Where ASP stores the configuration?
What configuration?
Your user folder stores batch settings, defaults, presets, the cache and a pointer to the catalogs.
The layout changes are stored in the appropriate Qt places, which on Windows is in the registry, on Linux somewhere under ~/.config and PLIST on MacOS where I forgot the exact location...
cheers
afx
bee
motherboard: gigabyte p35-ds3l
processor: e3110 3ghz dual core
ram: 2gig
Video Card: nvidea 8600gts
sound_card: realtek
Hard_Drive_Capacity: 600gb
Monitor/Display Make & Model: planar px2710mw
Post by bee »
I have what sounds like the same symptoms. After deleting a couple of photos it will crash. Might crash on the first photo, or might make it to the 3rd or 4th before crashing. I am running the current aftershot trial on windows 7. After uninstalling aftershot, deleting the catalog, and running CC registry cleaner. I reinstall and have the same problem,this time not using the catalog function.
kaymann
motherboard: ASUS P8P67 PRO REV 3.1
processor: Intel i-7 6800K
ram: 32 GB
Video Card: NVidia GeForce RTX 2060
sound_card: Onboard
Hard_Drive_Capacity: 3.5 T
Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Post by kaymann »
I deleted a couple of files and got a C+++ error on the next restart. If I ignored the C+++ error everything continued to work fine. If I clicked OK or Ignore or Cancel, ASP shut down. If I stay in file system no C+++ error. It took a catalog delete and new catalog to fix...
It seems fairly consistant delete files/empty folders and problems will show up. Already reported to monkey.
cluhn
System_Drive: N/A
ram: 8096
Post by cluhn »
my problem seems to be resovled, sorry for the late answer but i had to test it for a longer period..
Ich resetet the size of my cache to 1024mb and the problem never happend again. (I configured 2048mb for months ago..)
