[BUG] As shot WB can be copied but is not applied
Bugs & Suggestions
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Copy WB (as shot) from one image to another will change the values displayed in the WB tool, but it will not change the applied white balance, as it is still set to as shot (it would need to switch to custom) which makes copying the WB rather tedious...
A manual switch to As Shot is needed.
cheers
afx
gareth
operating_system: Windows 8.1
motherboard: Acer Aspire TC-605
ram: 12Gb
Video Card: NVIDIA GeForce GTX 745
Hard_Drive_Capacity: a few TB
Monitor/Display Make & Model: AOC 2369M sRGB
Re: [BUG] As shot WB can be copied but is not applied
Post by gareth »
so you switch the first picture to custom (which does not alter that image) then copy the custom setting to all the other images, yes?
One could have a long debate about whether 'copy WB as shot' means to copy the 'as shot' menu item or to copy the settings of the source image :-)
ex-Bibble - mostly OLY E-510 and E-M5 + Win 8
grubernd
System_Drive: N/A
Post by grubernd »
/sarcastic mode ON
did WB copy ever work since the first betas of B4 and from there on?
/sarcastic mode OFF
it always had me stunned that WB copy was the one thing that always made trouble.
Bibble since 2004. Aftershot until 2020. From then on darktable.
afx
System_Drive: N/A
Post by afx »
gareth wrote:so you switch the first picture to custom (which does not alter that image) then copy the custom setting to all the other images, yes?
Yes, that is the standard workaround.
Which would be exactly the same... The settings are copied. But in this case a clean copy is not what the user intends.
What is the user expectation? To see the copied WB applied, not to see a verbatim copy.
As Bernd wrote, that is not new....
cheers
afx
