I'm archiving several recorded tv shows per DVD and I'd like the
playback to return to the main menu at the end of each show.
Right now when you finish playing back one show, it just jumps into
the next show and after the last show it jumps back to the start of the
first show like an endless tape.
How do you insert a "retun to main menu" on the disk between shows?
Return to menu after/between shows?
orion404
Re: Return to menu after/between shows?
I had the same problem and could not find the setting in the documention but after a lot of searching finally found the switch.
I'm on MF 3 so the menus may be slightly different than yours:
* Navigate to the main window 'Add/Edit Video'
* Click on the 'Project Settings' icon in lower left
* Uncheck 'Auto Repeat' box
* Drop-down menu 'After Playback' should now be activated
* Choose 'Back to Menu' option
This will give you the setting you're looking for.
