Subforums ready to use
FrankX
operating_system: Linux
System_Drive: X
Post by FrankX »
Finally there are subforums - thank you!
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Subforums ready to use
Post by afx »
And with andreas help:
Use
Code: Select all
http://forum.corel.com/EN/search.php?search_id=newposts&fid[]=96&fid[]=95&fid[]=94&fid[]=93&fid[]=90
to find all new posts in the AfterShot section regardless of subforum.
(any ideas how to quote this so that it just works? The board thinks it needs to interpret parts of it....)
cheers
afx
Edited again to update the search string and to protect the URL in a code statement.
claudermilk
Post by claudermilk »
Thank you!
Bibble transplant
elslunko
System_Drive: S
Post by elslunko »
Thank you guys, really appreciate the subforums.
tintin
processor: Ryzen R5 3600X
Post by tintin »
thank you very much!
with the sub-forums it is much more comfortable now!
maybe one question.... there are a lot of threads that are worth to be shifted from the 'General Questions & Getting Started' sub forum to the plugins subforum. could you please arrange that?
here is a list with the threads i found.....
thanks a lot!
tintin
ADMIN EDIT
ALL posts in list moved to Plug-ins sub-forum as requested if there are any more please make further lists in new posts below - BrianCee
my plugins on the official plugins homepage
If you find my plugins helpful, please make a donation to support further developments - just click here, thank you!
andreas
System_Drive: X
motherboard: Asus in Workstation and Dell XPS Notebook
processor: i7-980 and i7-2720QM
ram: 12GB - 8GB
Video Card: ATI FireGL
sound_card: on board
Hard_Drive_Capacity: 4.5TB Rd10
Monitor/Display Make & Model: Samsung Syncmaster 2343sw
Post by andreas »
I see sometimes problems which looks like the newposts search is not finding all posts. Another possibility is to use the unread posts search:
Code: Select all
http://forum.corel.com/EN/search.php?search_id=unreadposts&fid[]=90,93,94,95,96
In each sub forum it is possible (top right link) to mark all posts read as a starting point.
Andreas
Linux - not Windows
tomsi42
Post by tomsi42 »
It looks to me that both links fails to find all unread posts.
afx
System_Drive: N/A
Post by afx »
tomsi42 wrote:It looks to me that both links fails to find all unread posts.
The one in the second post works just fine for me...
cheers
afx
tomsi42
Post by tomsi42 »
cheers
afx
Doesn't work for me - it show nothing; and there should be many - I have many unread posts in all subforums except the General Questions one.
afx
System_Drive: N/A
Post by afx »
Do you see unread posts when you access the forums directly?
cheers
afx
tomsi42
Post by tomsi42 »
Yes, that's why I think there is something wrong.
I am using Firefox; but got the same with Internet Explorer.
andreas
System_Drive: X
ram: 12GB - 8GB
Post by andreas »
Most time it works here but sometimes not. I do not see, whats different...
Andreas
Linux - not Windows
