asGPS: a geocoding plugin for ASP
AfterShot Pro Plugins
binoyte
operating_system: Linux
System_Drive: Z
Re: asGPS: a geocoding plugin for ASP
Post by binoyte »
many thanks ! By the way I'll try to update the French translation which is perfectible.
Darktable 3. Bye bye aftershot.
andreas
System_Drive: X
motherboard: Asus in Workstation and Dell XPS Notebook
processor: i7-980 and i7-2720QM
ram: 12GB - 8GB
Video Card: ATI FireGL
sound_card: on board
Hard_Drive_Capacity: 4.5TB Rd10
Monitor/Display Make & Model: Samsung Syncmaster 2343sw
Post by andreas »
Regarding the problems in zenPhoto: This looks like a zenPhoto problem. If you look into the exif data with exiv2, you will see the correct rationale values for the position. There is no chance to code the "N", "W" etc. into this exif fields. Also Darktable displays my test images in the correct position. They also show up correctly in panoramino / google maps.
There may be a ref problem in asGPS with negative altitudes. I will correct it in version 1.3.3.
Andreas
Linux - not Windows
binoyte
System_Drive: Z
Post by binoyte »
andreas wrote:There is no chance to code the "N", "W" etc. into this exif fields.
In fact they already are. I tried this command :
Code: Select all
$ exiv2 -pv misplaced.jpg  | grep GPS
0x8825 Image        GPSTag                      Long        1  424
0x0000 GPSInfo      GPSVersionID                Byte        4  2 3 0 0
0x0001 GPSInfo      GPSLatitudeRef              Ascii       2  N
0x0002 GPSInfo      GPSLatitude                 Rational    3  46/1 41/1 37080/6000
0x0003 GPSInfo      GPSLongitudeRef             Ascii       2  W
0x0004 GPSInfo      GPSLongitude                Rational    3  73/1 1/1 1079/6000
0x0005 GPSInfo      GPSAltitudeRef              Byte        1  0
0x0006 GPSInfo      GPSAltitude                 Rational    1  301/1
0x0009 GPSInfo      GPSStatus                   Ascii       2  A
It seems indeed this is a zenPhoto problem.
By default exivtool or exiv2 translates the exif. The
-pv
option shows plain exif.
Thanks for the time on my problem.
B.
andreas
System_Drive: X
ram: 12GB - 8GB
Post by andreas »
I did some further checks with zenphoto. I made some changes in asGPS regarding the altitude ref and reexported my test image. Now it was imported correctly into zenphoto. I checked, which values had changed and both exiftool and exiv2 report that the GPS values did not change at all. I tried with the already imported image, exported it and reimported it: wrong position. All new created jpegs: good position. Currently i cannot reproduce the problem.
Andreas
Linux - not Windows
andreas
System_Drive: X
ram: 12GB - 8GB
Post by andreas »
Exif in zenPhoto when GPS is displayed:
wrong positioned image
Code: Select all
Breitengrad:	56,48166662037
Breitengradreferenz:	N
Längengrad:	6,1498333333333
Längengradreferenz:	Ws`
Höhenlage:	3m
Höhenlagereferenz:	008d9d60
image with correct position:
Code: Select all
Höhenlage:	3m
Höhenlagereferenz:	00c7e008
What is shown in your images?
Andreas
Linux - not Windows
andreas
System_Drive: X
ram: 12GB - 8GB
Post by andreas »
Here is my workaround. I added the substr function in two lines in zp-extension/GoogleMap.php:
Code: Select all
 * $eturns coordiante information for an image
 * @param $obj
function getGeoCoord($obj) {
    $result = false;
    if (is_object($obj) && $obj->table == 'images') {
        $exif = $obj->getMetaData();
        if(!empty($exif['EXIFGPSLatitude']) && !empty($exif['EXIFGPSLongitude'])){
            $lat_c = explode('.',str_replace(',', '.', $exif['EXIFGPSLatitude']));
            $lat_f = round((float) abs($lat_c[0])+$lat_c[1]/pow(10,strlen($lat_c[1])),5);
            if (substr($exif['EXIFGPSLatitudeRef'], 0, 1) == 'S') {
                $lat_f = (float) -$lat_f;
            $long_c = explode('.',str_replace(',', '.', $exif['EXIFGPSLongitude']));
            $long_f = round((float) abs($long_c[0])+$long_c[1]/pow(10,strlen($long_c[1])),5);
            if (substr($exif['EXIFGPSLongitudeRef'], 0, 1) == 'W') {
                $long_f = (float) -$long_f;
            $result = array('lat'=>$lat_f,'long'=>$long_f, 'title'=>$obj->getTitle(), 'desc'=>$obj->getDesc());
    return $result;
This resolves the problem vhen refs are messed up. But the original problem remains: Who messes the ref values? ASP or php-exif or somethink in the zenPhoto database import?
Andreas
Linux - not Windows
binoyte
System_Drive: Z
Post by binoyte »
Wow what a workaround !
andreas wrote:What is shown in your images?
Same as you ! I've weird types after N/S E/W And I wonder about the relevance of the EXIFGPSAltitudeRef datas. Here is a screenshot of my mysql datas : http://tmp.benoitvarret.fr/misplaced_phpmyadmin.png
Thanks for your hack. I'll refer it on ZP forum : http://www.zenphoto.org/support/topic.php?id=14205
andreas
System_Drive: X
ram: 12GB - 8GB
Post by andreas »
so, asGPS version 1.3.4 is now compiled locally (lin/win). Waiting for the mac version. negative altitudes are now handled correctly - regarding the messed up options/exif mix in ASP.
Andreas
Linux - not Windows
andreas
System_Drive: X
ram: 12GB - 8GB
Post by andreas »
I sent a post regarding these problems to the mentioned zenphoto thread
Andreas
Linux - not Windows
andreas
System_Drive: X
ram: 12GB - 8GB
Post by andreas »
Thanks to Jonathan for the mac version.
Current asGPS v1.3.4 is available using asPluginManager or directly from the Corel plugin page: http://aftershotpro.com/plugins/index.html?plug=asgps
Andreas
Linux - not Windows
binoyte
System_Drive: Z
Post by binoyte »
Doesn't work for me. The map is still "locked".
andreas
System_Drive: X
ram: 12GB - 8GB
Post by andreas »
the info dialog shows 1.3.4?
Linux - not Windows
andreas
System_Drive: X
ram: 12GB - 8GB
Post by andreas »
sorry old html page included, will update the link.
EDIT: no, this is not the case. Yesterday I tested with just this version which worked. Digging into it...
Andreas
Linux - not Windows
binoyte
System_Drive: Z
Post by binoyte »
yes : 1.3.4 http://i38.servimg.com/u/f38/13/98/61/29/captur11.jpg
By the way, I found what's wrong with zenPhoto. Thanks for your help.
ogrizzo
operating_system: Mac
System_Drive: Q
processor: 2.8 Ghz Intel Core i7
ram: 8 GB
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Integrated Apple iMac 27"
Post by ogrizzo »
Same here: pane still freezed, version 1.3.4, running OSX 10.8.2
