using standard xml to sync with Imatch?
Gerard2
processor: AMD Athlon II X4 620 2.61GHz
ram: 4GB
Video Card: Ati radeon x1950xtx 512 mb
sound_card: onboard
Monitor/Display Make & Model: Dell FP2007
Post by Gerard2 »
I have used bibble in combination with imatch for a while, but especially in the B4 time. I am doing some test now how ASP and Imatch interact.
The trouble is that if I change something in ASP and force Imatch to update its xml things like labels and rating from ASP are shown. But if I then adjust these ratings and labels in imatch, they are not loaded into ASP. I tried refreshing, and i tried to merge metadata. It seems to me that the ratings are stored in the cr2.xml (the ASP xml) and that it ignores newer rating in the generic XML.
Is there any way to really sync these ?
claudermilk
Re: using standard xml to sync with Imatch?
Post by claudermilk »
You mean XMP (yes, it's really XML at it's root). I normally don't change ratings or tags from within IMatch--I do that in FastPictureViewer, but those settings are recognized across all three programs with no problem. I can play with it a bit, but don't recall ever seeing an issue--even in Bibble 5 days.
Bibble transplant
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Post by ferdinand-paris »
Gerard2 wrote:But if I then adjust these ratings and labels in imatch, they are not loaded into ASP. I tried refreshing, and i tried to merge metadata. It seems to me that the ratings are stored in the cr2.xml (the ASP xml) and that it ignores newer rating in the generic XML.
I am travelling at present and so it's hard to check this, but I thought that "Merge External Metadata" in ASP should work much as it did in B5. I'm fairly sure that this works for me, and that I've been able to sync ratings in both directions.
Are you working in file system mode, as I couldn't be sure that this will work in catalog mode? If it's still not working then it may be necessary to check your iMatch XML settings. The iMatch forum would be a better place to discuss that program's settings. Also, what file formats are we talking about? Just CR2? It's possible that there is a conflict between the sidecar and embedded XMP.
F_P
grubernd
operating_system: Linux
System_Drive: N/A
Post by grubernd »
ferdinand-paris wrote:but I thought that "Merge External Metadata" in ASP should work much as it did in B5.
careful with that in version 1.0.1.10 (maybe also older ones), big bug!!
http://forum.corel.com/EN/viewtopic.php?f=94&t=46166
Bibble since 2004. Aftershot until 2020. From then on darktable.
ferdinand-paris
ram: 4Gb
Ahhh yes, I forgot about that. Doesn't really affect me as I do almost all my metadata entry in iMatch, although sometimes I rate images in B5/ASP. The bug in essence is that non-blank values are overwritten with blank ones, isn't it?
F_P
grubernd
System_Drive: N/A
Post by grubernd »
ferdinand-paris wrote:Ahhh yes, I forgot about that. Doesn't really affect me as I do almost all my metadata entry in iMatch, although sometimes I rate images in B5/ASP. The bug in essence is that non-blank values are overwritten with blank ones, isn't it?
if you do a "Merge Meta", yes, all images except the currently highlighted get blank entries. and that is the really bad part because if you dont crosscheck or have the keywordpanel open and see the color change to all green, the error isnt visible.
Gerard2
ram: 4GB
sound_card: onboard
Post by Gerard2 »
i only tested it in a separate folder.
so probably dont use until the bug is gone
so it should work both ways; how would ASP tell which star rating is newer: from the date of the xmp?
