Cropping images to 16.9
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Re: Cropping images to 16.9
Post by Ken Veal »
SCRIPT BATCH PROCESS workflow
1 Place landscape and portrait images in separate folders
2 Go File-batch process
3 In batch process box-click browse
4 Select images in” Landscape Pics” folder
5 under save options in files of type-jpeg
6 Under files to process- Path of images show
7 Under type-select jpeg
8 In Folder field-Browse to “Landscape Processed Pics” folder
9 underSave mode- New Type
10 Check stop on error
11 Check silent mode
12 Under script Check use script-“addPSP P8File Locations” shows
13 Click drop down arrow to the right
14 Scroll to”Landscape Resize Ht 900Canvas 1600” and select it.It shows in script field
15 Click start
16 In Batch progress box Executing script path shows for each image and saving
17 Click OK
18 Images show in “Processed Landscape Pics “ folder
The thumbs are ok with top and bottom bars but the image, when double clicked, is sort of out of focus and poor quality in the screen and very big.They have no bars, is this because my monitor is not 16.9 or have I gone wrong somewhere.The size is given as 1200x675 ,is 109 KB and shown with 54% background
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Check your options on jpg save ie/ Load an image and do File --> Save As to desktop then bottom right click Options and see that your Compression Factor is set at 3 to maintain original Disk size.
If you could start a photobucket account you could upload images to there and would be able to see what you mean. You should have bars at the sides and not at the top and the image should remain at 900 pixels high.
Ken Veal
ram: 32 GB
Post by Ken Veal »
1 Opened image
2 clicked jpeg options
3 In save options box-under compression-factor =20-changed to 3-OK
4 Clicked start
5 Right clicked image in "Processed Landscape pics" folder
6 chose send to desk top
7 Double clicked desk top short cut
8 Image shows the same as previously in PSPro
9 Right clicked image-File-save as-saved in my pics folder
10 Thumb shows with top and bottom bars
Ken Veal
ram: 32 GB
Post by Ken Veal »
I have opened a photobucket account and uploaded an image"943".My user name is editman1
hartpaul
ram: 8 Gb
Post by hartpaul »
Is this the image you mean?
http://i1164.photobucket.com/albums/q56 ... AGE943.jpg
I cannot see any bars there at all
The actual image size when you click through the thumbnail to get a larger image is 620 x 348
When attempting to post an image all you neeed to do is place your cursor over the image and a drop down box shows a Share|Copy box
Placing your cursor over the Direct Link window will cause it to be copied to your clipboard.
Then in a post here click Img button and paste that link (control V) between the tags.
Ken Veal
ram: 32 GB
Post by Ken Veal »
Thought I followed your instructions and ended up with this!
[img]v[img]lbums/q564/editman1/IMAGE943.jpghttp://i1164.photobucket.com/albums/q564/editman1/IMAGE943.jpg[/img][/img[img][img]http://i1164.photobucket.com/albums/q56 ... cket.com/a][/img][/img]
1 Went to photo bucket
2 hovered over diect link
3 Clicked Img here
4 Ctrl V
Ken Veal
ram: 32 GB
Post by Ken Veal »
another problem I had with trying to look at the image here in this post was a message saying "Firefox does not know how to open this address protocol jpgttp is not associated with any programme."
hartpaul
ram: 8 Gb
Post by hartpaul »
Image[/imgImage[/img]
Hi Kenneth,
I see you have been having real troubles with basics.
I was going to remind you that you could edit your posts here if there was something out of order.
In that quote I can see and perhaps predict what you have done. the
indicates that you clicked the IMG button alright, but when you went to paste the image URL by typing Control V you raised the control key before pressing the v and so you got the v between the img tags rather than the pasted URL.. You must press and hold the Control Key down and then hit and raise the V key and lastly raise the control key.
I would have thought if you knew how to edit you would have gone back and erased that portion. Then it looks like you pasted the URL , realised you had made a mistake and hit the delete key a number of times to correct, when you should have hit the backspace key. So you finished with "lbums/q564/editman1/IMAGE943.jpg" then went on and got confused and so that posting is a mish mash of half baked URLs
And this is what it should have looked like:
hartpaul
ram: 8 Gb
Post by hartpaul »
Because the script is producing the landscape image with 900 pixels height on a canvas that is 900 pixels high. You should never , never get top and bottom bars, only side bars. To get top and bottom bars indicates that you are resizing your image to less than the canvas height, or sizing the canvas height larger thaan your image height.
Ken Veal
ram: 32 GB
Post by Ken Veal »
This is a screen shot of a thumb in my pics
Ken Veal
ram: 32 GB
Post by Ken Veal »
The above is the image that has had the script applied to it as listed above in my workflow for a landscape image.
Thank you for your patience in helping me here-as you can see I am new to all this.Have never use ctrl v before,always used copy-paste.Hope you can get me out of this mess I am in......Ken
*Could not submit this post with the image because a message showed saying that it must not be above 950 pix wide.
The image is no. 940 in photo bucket (editman1)
hartpaul
ram: 8 Gb
Post by hartpaul »
OK we seem to be having some difficulties here. Photobucket and this site have limitations on size or images that can be posted. Can you email me the large image that you are having troubles with , and your result full size for each.
Edie
motherboard: Gyabyte GA-MA790FXT-UD5P
processor: Amd Phenom II X4 965 3400mz
Video Card: ATI Raedon HD5800 Series 1GB Ram
sound_card: AMD HD Audio Device
Hard_Drive_Capacity: 800GB
Monitor/Display Make & Model: LG Flatron w2753v and Samsung SyncMaster 2053BW
Post by Edie »
An excellent series of tutorials!!!!!
johnsmitchell2
Post by johnsmitchell2 »
Great tutorial -- thank you!
I do a great deal of aviation and sports photography; may shoot as many as 7,000 or so photos during an airshow. I screen them down to about 10% to 20% of the best in a slide view program then use Paint Shop Pro for cropping, 16:9 and enhancement. Because of image size and placement every crop is a bit different so I don't think I can use a script that you have so excellently described.
My challenge is that the aspect ratio doesn't hold over multiple resizings. I have to manually calculate every so often, 5 photos or so and then resize manually to correct what appears to be drift.
Additionally and more annoying, the pixel width and height boxes often default to 1:1 even though I can see that the crop box on the screen is clearly not 1:1. The aspect ratio width and height boxes will sometimes return to their correct setting if I go to another part of the program but this is time consuming and very annoying. Finally, and recall I'm working as fast as possible (my wife says I spend too much time on the computer!) the Maintain Aspect Ratio box seems to uncheck at random intervals. If I fail to note the uncheck in my admitted haste, I have to go back to Last Applied and manually check the 16:9 ratio. Takes time and is quite annoying, particularly if the height and width boxes have defaulted to 1:1.
One more thing that isn't on this subject: due to the large number of photos I'm working from an external hard drive. In order to reopen the file I'm working with following the completion of 10 to 15 photos I have to click through close to 10 layers to get back to the file. This too seems inconsistent as on few occasions the working file appears magically in file open. I realize this might be part of the Windows protocol but would appreciate any suggestions.
Thank you very much,
John Mitchell
hartpaul
ram: 8 Gb
Post by hartpaul »
Ok Here is how I would go with 1000s of pictures (presuming them all to be less than 16 : 9 and no panoramas.
(This will not work with panoramas which are more than 16 : 9 ratio)
1. Set up some folders on the desktop to work with . The desktop because they are easy to find. The ZZZ in front because in a tree list they will be easily spotted at the bottom. My suggestions are as shown.
Image Copies - contains copies of your original images. You will crop these in PSP and Save (not Save AS)
All images inthe Image Copies folder may be over written.
ZZZTemp - will be where your resized images are sent.
ZZZWorking - where all the new canvas images at 16:9 ratio will be saved.
2. Using Irfanview for a bulk resize -
Each of the following shows how to :
Choose Batch Conversion,
Setting up the images for resizing, and the save folder and acces to the advanced features.
Advanced settings for resizing to a common height in this case 900 pixels.
The script has already been mentioned earlier.
Here is a link to a contact sheet of the original images:
http://i477.photobucket.com/albums/rr14 ... alpics.jpg
and after the single script applied , all images both landscape and portrait are on a 16: 9 canvas:
http://i477.photobucket.com/albums/rr14 ... images.jpg
