Plug-ins not recognized
AfterShot Pro Plugins
gjtoth
operating_system: Linux
System_Drive: T
ram: 2GB
Hard_Drive_Capacity: 500GB
Monitor/Display Make & Model: Gateway 23" LCD
Post by gjtoth »
I'm running OpenSuse 11.4
Although, ASP says the plug-ins are installed, they don't show up under the plug-in tab. Suggestions?
dFlyer
System_Drive: N/A
Re: Plug-ins not recognized
Post by dFlyer »
What version of ASP are you running and is it all or just some?
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
gjtoth
System_Drive: T
ram: 2GB
Post by gjtoth »
dFlyer wrote:What version of ASP are you running and is it all or just some?
Running the latest version. It's all the ones I downloaded and installed. There are a few there: B&W, Color Equalizer, and Nostalgia. I installed anything else I could get my hands on and they're not showing up.
dFlyer
System_Drive: N/A
Post by dFlyer »
I myself believe there are some major problems with ASP 1.0.1.10. Not sure if this will fix all your problems but if you move /opt/AfterShotPro/lib/libstdc++.so.6 to libstdc++.so.6~, it should fix at least typewriter, also if you check on the bibble5 support web page there is a fix for the texa linux plug-ins. The rest of the plugins all worked on my linux box so hopefully the typewriter fix will also fix the rest of your plug-ins. If you haven't yet you may want to check your printing as printing seems to also be a major problem with the current release.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
gjtoth
System_Drive: T
ram: 2GB
Post by gjtoth »
dFlyer wrote:I myself believe there are some major problems with ASP 1.0.1.10. Not sure if this will fix all your problems but if you move /opt/AfterShotPro/lib/libstdc++.so.6 to libstdc++.so.6~, it should fix at least typewriter, also if you check on the bibble5 support web page there is a fix for the texa linux plug-ins. The rest of the plugins all worked on my linux box so hopefully the typewriter fix will also fix the rest of your plug-ins. If you haven't yet you may want to check your printing as printing seems to also be a major problem with the current release.
Thanks very much. And, thanks for the printing heads-up. :)
gjtoth
System_Drive: T
ram: 2GB
Post by gjtoth »
Well, that didn't do the trick. However, I'm sure learning to get around in ASP. :D Thanks again.
dFlyer
System_Drive: N/A
Post by dFlyer »
Sorry to hear that, have you tried going to your .AfterShotPro/Plugins/ folder and deleting all the plug-in and just reinstalling them?
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
gjtoth
System_Drive: T
ram: 2GB
Post by gjtoth »
dFlyer wrote:Sorry to hear that, have you tried going to your .AfterShotPro/Plugins/ folder and deleting all the plug-in and just reinstalling them?
Nope. I'll try that and let you know how it goes. Thanks... again!
gjtoth
System_Drive: T
ram: 2GB
Post by gjtoth »
Well, this is odd. I don't have that folder in my home directory!
I created that folder and reinstalled the plug-ins. BINGO! We have lift-off! Thanks bunches.
dFlyer
System_Drive: N/A
Post by dFlyer »
Real odd, because that is where the plug-ins are installed. You may want to reinstall AfterShot Pro as these are all the folders and files located in /home/.AfterShotPro
drwxrwxr-x 14 gary gary 4.0K Apr 23 21:30 .
drwxr-xr-x 54 gary gary 4.0K Apr 23 21:23 ..
-rw-rw-r-- 1 gary gary 21K Apr 23 21:30 AfterShotPro.log
drwxrwxr-x 2 gary gary 4.0K Apr 23 21:14 batches
drwxrwxr-x 3 gary gary 4.0K Apr 23 21:30 cache
drwxrwxr-x 2 gary gary 4.0K Apr 23 21:23 CopySets
drwxrwxr-x 2 gary gary 4.0K Apr 23 21:14 defaults
-rw-rw-r-- 1 gary gary 1.4K Apr 23 21:14 Download.batch
drwxrwxr-x 2 gary gary 4.0K Apr 23 21:14 Gallery
-rw-rw-r-- 1 gary gary 7.2K Apr 23 21:24 hotkeys.xml
drwxrwxr-x 2 gary gary 4.0K Apr 23 21:14 layouts
drwxrwxr-x 8 gary gary 4.0K Apr 23 21:14 locale
drwxrwxr-x 2 gary gary 4.0K Apr 23 21:14 NoiseNinja
drwxrwxr-x 7 gary gary 4.0K Apr 22 10:44 PluginData
drwxrwxr-x 29 gary gary 4.0K Apr 22 10:40 Plugins
drwxrwxr-x 10 gary gary 4.0K Apr 17 20:15 Presets
-rw-rw-r-- 1 gary gary 835 Apr 23 21:15 Print.queue
-rw-r--r-- 1 gary gary 21K Apr 23 21:29 rootdb
-rw-rw-r-- 1 gary gary 899 Apr 23 21:14 SaveAs.batch
-rw-rw-r-- 1 gary gary 26 Apr 23 21:30 sequences.txt
-rw-rw-r-- 1 gary gary 1.1K Apr 23 21:14 softProofProfiles.xml
drwxrwxr-x 2 gary gary 4.0K Apr 23 21:15 User Profiles
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
