ATI MMC has the option to turn GOP (group of pictures) ON/OFF in the frame sequence settings.
Should it be on or off? Does VStudio 8 care?
To G.O.P. or not to G.O.P.
jchunter_2
THoff
It very well could, because when a GOP is closed, the timecode is inserted. If a decoder for either playback or transcoding relies on that to try to keep audio and video in sync to correct for small drifts (which often occur with analog captures), then you will see a progressive synch problem.rjgeisler wrote:I don't see that it matters in UVS unless it somehow affects the Audio sync!
