X5 Transition Bug in preferences.
alexcee
motherboard: Asrock 970 Extreme 3
processor: AMD FX8350
ram: 32 GB
Video Card: NVIDIA GEFORCE GTX 660
sound_card: ONBOARD
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: AOC 2436
Post by alexcee »
Hi All.
Just a heads up on a prob I have with the VideoStudio X5.
Settings >Preferences > Edit >Default Transition Effect
The transition I select here, no matter what I choose, reverts back to "Random" once "ok'd"
Is anyone else having this problem as this is a very annoying! The workaround this is to disable this option altogether and select manually.
Cheers
Alex
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Re: X5 Transition Bug in preferences.
Post by Kingston »
I see what you are saying, but the default transition I select is actually what I get on the timeline, despite "Random" showing back up.
Post by BrianCee »
Yes I see the same effect - but just like Kingston my VideoStudio always inserts the selected alternative in the current project , just that the preference wording always resets to Random .
Later Edit
In fact since I went to start a new project it appears that the new default set in Preferences (although the drop down still says Random) is used in all subsequent projects.
markguitre
motherboard: Quanta
processor: 2.3 Gigahertz 3rd Generation Intel Core i7-3630QM
ram: 12GB
Video Card: NVIDIA GeForce GT 630M
Hard_Drive_Capacity: 750GB
Post by markguitre »
So what is the solution for this so-called bug? I ask because I now have it, in VS Prox5. No matter how many times I set and save the default transition to "crossfade," it always diverts back to "random."
And no, I have never overlapped any clips.
Mark Lis
Post by BrianCee »
there is no solution because there is no problem. If you select "Crossfade" as your default in preferences then the crossfade transition is applied at every join between video clips as you insert them.
True if you now open Preferences again the drop down shows Random - but until you actually select Random VS will continue to insert crossfades in every project.
It doesn't seem to be the same in X6 - so perhaps if you find it a problem you should upgrade to X6.
