VideoStudio Pro X5 Crash while Rendering MPEG-4
Cerdiank
motherboard: MSI P67A-GD65
processor: Intel i7 2600k
Video Card: nVidia GTX 680
sound_card: Xonar
Post by Cerdiank »
Hi.
I recently decided to buy X5 upgrade to my X4; as seeing it has hardware support to some extra speed. Let me say also that I've had no issues at all with X4. There is no hardware changes in my system in using version to version of Videostudio.
  • i7 2600k
    nvidia gtx 680 using the latest driverset
X5 is indeed faster while rendering in MPEG-4 formats, however most of the time it crashes at random % of the rendering. Sometimes, it works perfectly. Sometimes.
"The program has encountered an unspecified error and has stopped functioning. Please contact Corel Technical Support and send the dump file for analysis."
EDIT: I installed the X5 software on to my other desktop, a slower machine Intel Core Duo/Quad Q9650 with a nVidia 8800 gt. VideoStudio X5 crashes the same exact way doing the exact same thing.
Any clues, advice, ideas?
Thank you in advance =)
slyng1
motherboard: ASRock Z68
processor: Intel Core i5-2500k
ram: 16gb
Video Card: Saphirre Radeon 6870
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: 2xDELL 2408WFP
Re: VideoStudio Pro X5 Crash while Rendering MPEG-4
Post by slyng1 »
I get a similar problem everytime i go to burn a project to blu-ray. I have yet to successfully author a BD-R. HELP!!
TerryF
motherboard: P35-DS3R
processor: 2.80 gigahertz Intel Core2 Duo
ram: 8gb
Video Card: NVIDIA GeForce GTS 250
Hard_Drive_Capacity: 1740GB
Monitor/Display Make & Model: Samsung SyncMaster 920N
Post by TerryF »
I have the same issue. I even upgraded to Windows 8 to see if the problem would go away but it did not.
All my attempts to render a Blu-ray of my project using a series of .vsp projects fail. They usually fail providing the following event log application entry related to module uvHTMPEG2.dll. I can find no reference to issues with this module on the web.
Log Name: Application
Source: Application Error
Date: 20-Dec-12 11:21:44 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: Terry-PC
Description:
Faulting application name: vstudio.exe, version: 15.0.0.0, time stamp: 0x4fc489dd
Faulting module name: uvHTMPEG2.dll, version: 0.0.0.0, time stamp: 0x4fc49463
Exception code: 0xc0000005
Fault offset: 0x00027bc6
Faulting process id: 0xeb0
Faulting application start time: 0x01cddee07d498df3
Faulting application path: C:\Program Files (x86)\Corel\Corel VideoStudio Ultimate X5\vstudio.exe
Faulting module path: C:\Program Files (x86)\Corel\Corel VideoStudio Ultimate X5\uvHTMPEG2.dll
Report Id: 7cd72315-4ada-11e2-bea9-001a4d4ec029
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-12-20T19:21:44.000000000Z" />
<EventRecordID>63413</EventRecordID>
<Channel>Application</Channel>
<Computer>Terry-PC</Computer>
<Security />
</System>
<EventData>
<Data>vstudio.exe</Data>
<Data>15.0.0.0</Data>
<Data>4fc489dd</Data>
<Data>uvHTMPEG2.dll</Data>
<Data>0.0.0.0</Data>
<Data>4fc49463</Data>
<Data>c0000005</Data>
<Data>00027bc6</Data>
<Data>eb0</Data>
<Data>01cddee07d498df3</Data>
<Data>C:\Program Files (x86)\Corel\Corel VideoStudio Ultimate X5\vstudio.exe</Data>
<Data>C:\Program Files (x86)\Corel\Corel VideoStudio Ultimate X5\uvHTMPEG2.dll</Data>
<Data>7cd72315-4ada-11e2-bea9-001a4d4ec029</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
TerryF
ram: 8gb
Post by TerryF »
Well, here's a clue.
I have been struggling with this off and on for days to no avail. Today I took a look at the project (.vsp file) where the attempt to create a Blu-ray was consistently failing. I found that it had a number of transitions with lengths of 0.10, 0.18, etc. etc. I don't have any idea how I managed to do that - the shortest transition length I use is 0.29. I fixed them all to be at least 0.29 and rendered to create a Blu-ray folder only. It worked.
I had not suspected any issue with the .vsp file simply because it had already rendered fine as a part of a dvd and it had also rendered without issue as an MPEG4 file.
If Blu-ray rendering can't deal with such short transition lengths it would be helpful if VideoStudio would flag them in the first place or not allow them to be so short.
So if your failure is showing up in event viewer as a uvHTMPEG2.dll issue, perhaps you could also check that there aren't any weird lengths in your transitions.
TerryF
ram: 8gb
Post by TerryF »
Please disregard my previous post re transition lengths. I just tried to render my whole project again and it failed again in the middle of the same .vsp file.
Thought I was on to something there...
TerryF
ram: 8gb
Post by TerryF »
Further re uvHTMPEG2.dll errors.
The odd thing is that I managed to produce a 1-1/2 hour or so Blu-ray a few months ago without encountering this problem. Nothing much of significance has been changed on my pc since then to my knowledge - same version with SP1 installed. I did upgrade to Windows 8 but that doesn't appear to have done anything either way.
I have uninstalled and reinstalled VideoStudio Pro X5 several times to no avail - and it's a nuisance doing that because it's tricky getting Smartsound Quicktracks to reactivate.
slyng1
ram: 16gb
Post by slyng1 »
Same problem for me as well.
So frustrated... Do people from COREL view this board? Can they help? I have about 5 different DMP files I can post/send.
Post by BrianCee »
These are USER to USER forums - run and staffed by users not Corel
One or two employees do visit these forums but not as an official or specific part of their duties but just to try and help - if you want to contact Corel technical support try here :- http://www.corel.com/corel/pages/index.jsp?pgid=800034
Asking for help on their facebook page also seems to get a response try here : https://www.facebook.com/corelvideostudio?fref=ts
