Panasonic G3 lens not corrected
marbly
Post by marbly »
I recently bought a Panasonic G3 + 14-42mm + 45-200mm kit to play around with. From my reading I have learned that Panasonic stores a lens profile in the lens firmware and it gets written to the raw file so that you don't need an external profile for the lenses. If you open the raw file in various raw processing programs the distortion is automatically corrected even though there is no external profile in the same sense as other lenses for other systems. I opened a raw file using Photoshop Elements 9/ACR 6.5 and the distortion is automatically corrected. I opened the same file in Lightroom 4.1 RC and it is automatically corrected. I opened the same file in ASP 1.0.1.10 and the distortion is not corrected. What am I doing wrong with ASP?
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: Panasonic G3 lens not corrected
Post by afx »
As far as I know Adobe is the only company that got the info from Panasonic on the encoding of the distortion parameters...
On the other hand, it is rather trivial to calibrate a lens:
http://forum.corel.com/EN/viewtopic.php?f=90&t=45815
cheers
afx
marbly
Post by marbly »
Thank you for the reply. I will take a look at that link.
marbly
Post by marbly »
I did a bit of additional checking and I see that the G3 and 14-42mm lens are in the ASP db of lenses, but then when you select them it says the lens is uncalibrated. This is exactly the same problem that I reported to Corel that existed in 1.0.0.39 and I also started a thread here about it:
http://forum.corel.com/EN/viewtopic.php?f=90&t=45194
It is very, very deceiving to have an impressive list of lenses in the db and then discover that many, many of them are not calibrated. Can someone explain what the rationale is for including a bunch of lenses that have no profile?
I was expecting that Corel would have fixed this in the new version released recently. Remove lenses that are there for no reason or provide profiles for them.
afx
System_Drive: N/A
Post by afx »
marbly wrote:I did a bit of additional checking and I see that the G3 and 14-42mm lens are in the ASP db of lenses,
Nope, they are not.
There is a difference between recognized lenses and lenses that have correction data in the lens DB.
You are mistaking a list of identified lenses with a correction database.
cheers
afx
Denis de Gannes
motherboard: Gigabyte- G31MX-S2
processor: Intel Core Quad CPU Q6700 2.66 GHz
ram: 4GB
Video Card: On Motherboard
sound_card: nk000
Hard_Drive_Capacity: 1820 GB
Monitor/Display Make & Model: AOC 2216Sw
Post by Denis de Gannes »
I am attaching a file processed by LR 4.1rc and ASP 1.1.10 from a Panasonic raw file Panasonic G 14-42mm lens with G3. It is my understanding that LR is in fact adjusting for the required Lens Correction necessary to proper render the m4/3 cameras and lenses. I am not seeing any difference in the files distortion wise, so I can only believe that ASP is making the same corrections.
Denis
Camera: Oly E300 & E510; ZD & OM Lenses; Panasonic G3
Software: PSP x4; Corel Video Studio Pro X3; PS CS6; SilkyPix 4; ASP 1; LR 5.4; Capture One Ex 7; Qimage Ultimate; VueScan.
marbly
Post by marbly »
Nope, they are not.
I could provide a screenshot, but I we all know that isn't necessary. ASP shows them in the dropdown lens db list, but then reports that they are not calibrated if you select them.
Again, you seem to be pretending here.
marbly
Post by marbly »
Denis de Gannes wrote:I am attaching a file processed by LR 4.1rc and ASP 1.1.10 from a Panasonic raw file Panasonic G 14-42mm lens with G3. It is my understanding that LR is in fact adjusting for the required Lens Correction necessary to proper render the m4/3 cameras and lenses. I am not seeing any difference in the files distortion wise, so I can only believe that ASP is making the same corrections.
Maybe it depends on which focal length used (I think one of my photos where it is very obvious was taken at 14mm). I suspect that 14mm is the worst. I could provide photos, but it seems superfluous since it is so glaringly obvious. Even so, I will try to find a bit of time today to do so.
Denis de Gannes
ram: 4GB
sound_card: nk000
I am sure ASP and LR are doing some initial correction on import based on the info for lens correction within the raw file.
Processing raw files, from m4/3 cameras and lenses, without the correction is a waste of time due to the design of the lenses, it is a basic requirement. This allows Panasonic and Olympus to reduce the size of the lens.
I am sure there is a case for additional correction using the lens correction features but the initial correction is needed to make to files usable.
I have just made another post with a file at 18mm as apposed to the previous file which is shot at 42mm. Clearly ASP is not making the required correction on import.
Last edited by Denis de Gannes on Sat Apr 21, 2012 1:01 am, edited 1 time in total.
Denis
afx
System_Drive: N/A
Post by afx »
marbly wrote:I could provide a screenshot, but I we all know that isn't necessary. ASP shows them in the dropdown lens db list, but then reports that they are not calibrated if you select them.
Yes, that is the list of known lens, not the calibration DB.
just because you do not want to accept that does not change it....
That list is taken straight from the lens table files.
Just because you do not like it, does not change reality.
cheers
afx
afx
System_Drive: N/A
Post by afx »
Denis de Gannes wrote:I am sure there is a case for additional correction using the lens correction features but the initial correction is needed to make to files usable.
AS has only one correction mechanism. And it is only usable if there is correction data in the lens files.
Unfortunately not all of the m4/3 lenses are covered.
See supportfiles/Profiles/LensProfiles/profile_micro43.txt
cheers
afx
Denis de Gannes
ram: 4GB
sound_card: nk000
cheers
afx
Ok my previous file was at the long end i.e 42mm. I have done another test at 18mm and compared the LR and ASP rendition with the camera jpeg. Clearly LR is making corrections to match the camera jpeg and ASP is not. Clearly an untenable situation.
Denis
greerd
System_Drive: Z
processor: Intel i7 920
ram: 12 GiB
Video Card: nVidia GeForce 260
sound_card: Onboard
Hard_Drive_Capacity: 5 TB
Monitor/Display Make & Model: Dell UltraSharp U2410
Post by greerd »
marbly wrote:I recently bought a Panasonic G3 + 14-42mm + 45-200mm kit to play around with. From my reading I have learned that Panasonic stores a lens profile in the lens firmware and it gets written to the raw file so that you don't need an external profile for the lenses. If you open the raw file in various raw processing programs the distortion is automatically corrected even though there is no external profile in the same sense as other lenses for other systems. I opened a raw file using Photoshop Elements 9/ACR 6.5 and the distortion is automatically corrected. I opened the same file in Lightroom 4.1 RC and it is automatically corrected. I opened the same file in ASP 1.0.1.10 and the distortion is not corrected. What am I doing wrong with ASP?
The 14-42 lens isn't corrected but the 45-200 is. In order to apply the correction the 'Enable correction' in the Detail tab must be checked.
marbly
Post by marbly »
Denis de Gannes wrote:I have just made another post with a file at 18mm as apposed to the previous file which is shot at 42mm. Clearly ASP is not making the required correction on import.
I just came back here to the forum and was about to fire up ASP and LR to create examples to post here of a photo taken at 14mm. I am glad to see that you have been able to verify the problem already though. Thanks for posting.
marbly
Post by marbly »
Denis de Gannes wrote:Ok my previous file was at the long end i.e 42mm. I have done another test at 18mm and compared the LR and ASP rendition with the camera jpeg. Clearly LR is making corrections to match the camera jpeg and ASP is not. Clearly an untenable situation.
Yes, I agree.
