I own VS9 but have hesitated to install it, remembering "if it's not broke, don't fix it," and being (almost) happy with VS8 as it is. At least I know the needed workarounds.
If I do install VS9, can I go right on using VS8?
Keith
Can UVS9 run parallel on 1 computer with UVS8?
jchunter
Keith,
Yes, you can still use VS8.
However, when you install VS9, you will install some common .dlls in the burning engine that will affect VS8 (and other Ulead products). This burning engine update seems to fix the OOS problem for VS9 but I don't know if it also fixes it for VS8.
Why don't you try installing VS9 and see if there is an OOS problem in VS8?
John
John
