!00% CPU USAGE
Chris R
!00% CPU USAGE
Post by Chris R »
I suddenly have a problem opening any video file. The CPU usage goes to 100% when I just try to open the "My Video" folder! I'm running Windows XP Home, 512 MB, AMD 2400 XP processor. I've made lots of copies from VHS before, and I've never encountered this. I'm using Studeo 7 SE and ADS DVD Express to capture. I've run anti-virus and spyware searches with nothing found. Any suggestions?
THoff
Post by THoff »
That may be caused by Explorer trying to build thumbnails, especially if they aren't being cached.
Open up Windows Explorer (not Internet Explorer), go to Tools -> Folder Options -> View and make sure the "Do not cache thumbnails" option is OFF, and that the "Launch folder windows in separate process" is ON.
Now when you try to open the My Video folder and the CPU utilization goes to 100%, you should be able to find an extra EXPLORER.EXE process in the Processes list in Task Manager. If you kill it, the thumbnail generation will stop, and you can continue to explore the current folder, and change the view from Thumbnails to something else.
Alternatively, you can change the Priority of the CPU-hogging Explorer process to low, and allowing it to generate the necessary thumbnails in the background without impacting system response (except for possibly disk I/O).
Chris R
CPU Usage
Post by Chris R »
Changing the folder settings had no affect - the cache was not cheched, and launching folders in a separate process did not generate another Explorer.exe for me to kill. Changing the priority to Low only made a percent or two difference.
jwarner
Post by jwarner »
Open the Windows Task Manager to see what Application or Process is using all the resources. In the Process tab, you can click on the CPU column to sort by usage.
It may be easiest to open the Task Manager before you create the problem (use Ctl/Alt/Del or right click on Task Bar and Select Task Manager).
Also have a look at memory usage, something may be causing the page file to expand out of control.
Chris R
CPU Usage
Post by Chris R »
For some reason Explorer.exe is the culprit. Everthing is fine until I try to open the My Video folder or a video file. Then Explorer.exe uses 99% of the CPU usage which goes to 100%! It's never done this in the past, that's what's so strange.
THoff
Post by THoff »
Are you using the Classic View or the Tasks View?
Chris R
CPU Usage
Post by Chris R »
Thanks for the links! I removed the media preview command outlined in the MovieCodec link, and it worked! Whew, what a relief!
