First of all: highlight recovery is finally fixed and results are as good as or better than with other applications I've tried - thanks very much for that to all developers! I've used Bibble/ASP since 2007 and the HR bug has been there from the start. It's so good to see that it is fixed now, and not only that: working very very well with my Olympus files.
One problem still remains, though: I see coloured pixels, jaggies and staircase artefacts at high-contrast edges. The problem gets more severe if I apply sharpening (it doesn't matter if I use the in-built algorithm, wavelet sharpen or Noise Ninja's USM). Please have a look at the attached screenshot (you'll probably only see the problem at 100%). ASP results are on the left, on the top-right you see the ooc jpg and below the result RawTherapee delivers. I think it could be the demosaicing algorithm (mybe in combination with another bug) as it occurs more severely with cameras that have a thin AA filter (like the Olympus E-5 or the E-M5).
Am I the only one who sees this? I find it quite annoying; the results of RawTherapee, Capture One, Silkypix, DxO and Lightroom are much smoother and more correct.
Cheers
Frank
Bug: weirdly coloured pixels and artefacts at high-contrast
Jeff Stephens
- motherboard: several
- processor: Opterons and Atoms
- ram: Bunches
- Video Card: something cheap
- sound_card: on board
- Hard_Drive_Capacity: pretty big
- Monitor/Display Make & Model: several
Re: Bug: weirdly coloured pixels and artefacts at high-contr
Hi Frank,
Thanks for uploading these samples to us. We're looking into it right now.
Cheers, Jeff
Cheers, Jeff
Fraenzken
- ram: 4 GB
- Monitor/Display Make & Model: IIyama ProLite E1900S
Thank you very much, Jeff!Jeff Stephens wrote:Hi Frank,
Cheers, Jeff
Cheers
Frank
my photos: http://naturfotos.bplaced.net
Zarastro
- System_Drive: N/A
- motherboard: M4A89TD
- processor: AMD Athlon X6 1075T
- ram: 16 GB
- Video Card: Point Of View GeForce GT 620 1024MB
- Hard_Drive_Capacity: 1300 GB
- Monitor/Display Make & Model: Dell WA2209
Frank, two questions:
1. Do these artifacts appear on the screen before exporting the raw images to the disk?
2. Did you enable "Output sharpening" in your output batch settings?
i think you can also see the weirdly colored pixels here in this thread http://forum.corel.com/EN/viewtopic.php?f=90&t=4618 the third photo on the models neck check out the full size on the link. it appears both on screen and in the exported file
Fraenzken
- ram: 4 GB
They appear both on the screen and in the exported file. Output sharpening was disabled.Zarastro wrote:Frank, two questions:
