[BUG] Auto Contrast still useless [1.0.1.10]
Bugs & Suggestions
thufor
operating_system: Linux
System_Drive: B
Post by thufor »
Auto Contrast seems to be running very early in the queue (definitely before Exposure), which makes it rather useless. This defeats the purpose of Auto Contrast rather spectacularly.
Example:
1. Choose a picture without shadows (e.g. high key).
2. Dial in negative Exposure (e.g. -0.7 EV).
3. Now apply Auto Contrast.
Result: totally underexposed histogram pushed well to the left.
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Re: [BUG] Auto Contrast still useless [1.0.1.10]
Post by Tadjio »
What AutoLevel settings did you use?
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
thufor
System_Drive: B
Post by thufor »
Sensible ones ;-) 0.002 and 0.001. If you use Auto Contrast before applying Exposure compensation (omit step 2) it works ok. This points to Auto Contrast using histogram from very early stage in the queue. Auto Contrast should use histogram from very late in the queue, as it did in Bibble 5. ASP basically broke Auto Contrast.
Tadjio
sound_card: Sound
Post by Tadjio »
Just curious - have you tested AutoLevel the same way?
Tadjio
thufor
System_Drive: B
Post by thufor »
No, not until now (since I don't use Auto Level...). I just tried and it looks like Auto Level is completely broken and underexposes even without negative Exposure.
Tadjio
sound_card: Sound
Post by Tadjio »
I have tried to reproduce your scenario and I can't, either with Canon or Olympus Raw files.
Could you post screenshots of your image (with clipping) and curves histogram before and after?
Interestingly, AutoLevel appears just before Exposure in the AfterShot pipeline but no AutoContrast. Curves is almost last.
Tadjio
gregglee
motherboard: Asus Sabertooth 990FX R2.0
processor: AMD FX-8350 8core 4600 MHz
Video Card: nvidia GTX 660ti
sound_card: on board
Hard_Drive_Capacity: 10 TB
Monitor/Display Make & Model: viewsonic vb2365WB + LG 1933TR
Post by gregglee »
thufor wrote:Sensible ones ;-) 0.002 and 0.001. If you use Auto Contrast before applying Exposure compensation (omit step 2) it works ok. This points to Auto Contrast using histogram from very early stage in the queue. Auto Contrast should use histogram from very late in the queue, as it did in Bibble 5. ASP basically broke Auto Contrast.
Those were probably sensible for Bibble5 but since ASP is broken I decided to ignore what it "should" do and just experiment. For my equipment, with the new release, shadow .001 and highlight .02 work with auto contrast most of the time. Actually HL clip from .02 to .1 it pretty much the same. Note in B5 I used clips of .002 and .02.
The new release didn't fix the irregular "sticky" response to changes in clip levels, but the result of auto contrast and auto levels seems more reasonable than before, once you discover the clip settings for your equipment and tastes. (Many like a more aggressive clip than I do.) The new release is not back to Bibble5 performance, but of course B5 didn't get every image right either.
Gregg Lee
12 miles from Glen Rose, Texas
camera equipment
