Typewriter Plugin not loading post Upgrade to V1.0.10.1
Hobgoblin
operating_system: Linux
System_Drive: N/A
Post by Hobgoblin »
Can someone confirm if this is an issue peculiar to Linux Mint 11, is it working for others?
AftershotPro.log reports:
46751.457: SettingsWindow::addTabs() - ui file missing: "/opt/AfterShotPro/supportfiles/tools/net.sadman.aftershot.typewriter"
The ui file is still there.
I've deleted and reinstalled the plugin, no errors reported at installation.
But no entry in Tabs.
FWIW: Its still working well in WinXP .
R.
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Typewriter Plugin not loading post Upgrade to V1.0.10.1
Post by afx »
Hobgoblin wrote:Typewriter Plugin not loading post Upgrade to V1.0.10.1
Yup, some change in the bundled libs leads to this. Sadman needs to recompile the Linux version.
cheers
afx
kaymann
motherboard: ASUS P8P67 PRO REV 3.1
processor: Intel i-7 6800K
ram: 32 GB
Video Card: NVidia GeForce RTX 2060
sound_card: Onboard
Hard_Drive_Capacity: 3.5 T
Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Post by kaymann »
Same for Win 7 loads and visible but applies no text to the photo... Shut down ASP and Restart and Text is still in dialog box but no text on photo...
afx
System_Drive: N/A
Post by afx »
kaymann wrote:Same for Win 7 loads and visible but applies no text to the photo... Shut down ASP and Restart and Text is still in dialog box but no text on photo...
I just posted images in the Corel forum with TypeWriter applied (via a preset) running on a Windows 7 box...
cheers
afx
kaymann
ram: 32 GB
sound_card: Onboard
Post by kaymann »
Mine shows none for font and drop down will not allow any of my fonts to show...
dFlyer
System_Drive: N/A
Post by dFlyer »
I can confirm Typewriter not working on Ubuntu 12.04 beta2 with current upgrade to V1.0.1.10 of ASP.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Jige_24
Post by Jige_24 »
ASP 1.0.10.1 under Windows XP, Type writer is OK.
kaymann
ram: 32 GB
sound_card: Onboard
Post by kaymann »
So I found the fix is to repeat all my fonts in the appdata folder C:\Users\Your_Name\AppData\Local\Corel\AfterShot Pro\PluginData\typewriter.
That sounds a little outta there... Has anyone found a better solution like a pointer to the already established win fonts folder?
afx
System_Drive: N/A
Post by afx »
kaymann wrote: So I found the fix is to repeat all my fonts in the appdata folder C:\Users\Your_Name\AppData\Local\Corel\AfterShot Pro\PluginData\typewriter.
That is the default location.
A plug-in specific directory in the PluginData directory in the AS user folder.
Been that way since the latest SDK was published.
cheers
afx
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
There is a temporary Fix.
See sadman's response in the other place.
http://support.bibblelabs.com/forums/vi ... 98&t=16692
kaymann
ram: 32 GB
sound_card: Onboard
Post by kaymann »
Hobgoblin wrote:There is a temporary Fix.
Thanks!
a file named
typeWriter.cfg
A text file containing the path to your font folder (typically c:\windows\fonts)
located in C:\Users\Your_Name\AppData\Local\Corel\AfterShot Pro\PluginData\typewriter\
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
Thanks!
a file named
typeWriter.cfg
Your reply seems somewhat irrelevant in this context.
Perhaps you meant to respond to 'afx's post rather than mine, or intended to reply to 'sadman' on the Bibble Forum. :wink:
R.
kaymann
ram: 32 GB
sound_card: Onboard
Post by kaymann »
Thanks!
First create a file named
typeWriter.cfg
Which is a text file containing the path to your font folder (typically c:\windows\fonts)
Place the typeWiter.cfg file in C:\Users\Your_Name\AppData\Local\Corel\AfterShot Pro\PluginData\typewriter\
No offense meant. It was simply a way to help others so they would not have to wade through 18 pages to find the fix buried 3/4 of the way through. The thank you was sincere. I had seen that post before and checked the first and last couple of pages, but you inspired me to read all 18.
Ultimately it seems zText handles fonts in a more user friendly manner with more variables and will be my text factory for the time being.
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
kaymann wrote: <snip>
No offence taken. :)
I simply felt that without linking your post back to' sadman's reply in the other place it was unclear where you were coming from.
Cheers,
R.
