[BUG] ASP 1.0.1.10 - Randomly changing Curves histogram
Bugs & Suggestions
thufor
operating_system: Linux
System_Drive: B
Post by thufor »
1. Select RAW image (doesn't seem to happen with JPGs).
2. Enable/Disable/Enable/Disable/Enable/Disable... Curves, making sure that the curves are flat as they come with standard installation of ASP.
Result: Histogram on Curves panel changes randomly with each enable/disable click...
dFlyer
System_Drive: N/A
Re: [BUG] ASP 1.0.1.10 - Randomly changing Curves histogram
Post by dFlyer »
I can't reproduce what your saying here. My raw format is Sony A700. What raw format are you working with?
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
thufor
System_Drive: B
Post by thufor »
The changes are mostly visible on the Curves panel histogram, not the main histogram, although sometimes happen there as well. The changes are also not very dramatic, unless there are clipped shadows -- then the shadow clipping jumps up and down rather significantly.
CR2, Canon EOS 50D.
Code: Select all
Application vers.: 1.0.1.10
Product Name: AfterShot Pro Registered
Built on:     Sun Apr 1 2012
Platform:     Linux
Language:     en
App Path:     /opt/AfterShotPro/bin/AfterShotPro
System Home:  ../supportfiles
User Home:    /home/thufor/.work/.AfterShotPro-home
Prefs Home:   /home/thufor/.config/Corel/AfterShot Pro.conf
Processors:   4
CPU Threads:  4
I/O Threads:  1
B. In-flight: 2
RAM:          7483 MB
SIMD Version: SSE2
Build Mode:   Release
Issue:        Fedora release 16 (Verne)
Kernel:       Linux version 3.3.1-3.fc16.x86_64 (mockbuild@x86-12.phx2.fedoraproject.org) (gcc version 4.6.3 20120306 (Red Hat 4.6.3-2) (GCC) ) #1 SMP Wed Apr 4 18:08:51 UTC 2012
====================  Plugins  =====================
      Name:
Identifier:
   Version: 1.0.0
      Path:
Identifier: sph.FatToni
   Version: 0.31.0
      Path: <User Home>/Plugins/FatToni.afplugin
Identifier: sph.grain
   Version: 0.31.0
      Path: <User Home>/Plugins/Grain.afplugin
Identifier: com.SMP.Nostalgia
   Version: 1.0.5
      Path: <User Home>/Plugins/Nostalgia.afplugin
Identifier: sph.SiliconBonk
   Version: 0.32.0
      Path: <User Home>/Plugins/Silicon Bonk.afplugin
Identifier: USM
   Version: 0.2.0
      Path: <User Home>/Plugins/USM.afplugin
Identifier: com.kbarni.vigne
   Version: 1.0.2
      Path: <User Home>/Plugins/Vigne.afplugin
Identifier: sph.waveletdenoise
   Version: 0.31.0
      Path: <User Home>/Plugins/Wavelet Denoise.afplugin
Identifier: sph.waveletsharpen
   Version: 1.34.0
      Path: <User Home>/Plugins/Wavelet Sharpen3.afplugin
Identifier: tin.tin.zchannelmixer
   Version: 2.0.2
      Path: <User Home>/Plugins/zChannelMixer.afplugin
      Name: Black and White
Identifier: com.corel.BlackAndWhite
   Version: 1.0.0
      Path: <System Home>/plugins/Black and White.afplugin
Identifier: com.corel.equalizer
   Version: 1.0.5
      Path: <System Home>/plugins/Equalizer.afplugin
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
thufor wrote:Result: Histogram on Curves panel changes randomly with each enable/disable click...
I can reproduce this with NEFs.
No visual impact on the image it seems but the histogram changes....
Time for the monkey.
cheers
afx
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
thufor wrote:1. Select RAW image.
Please can you explain a little more what you are doing and what is happening - perhaps with screen shots?
What do you mean when you say "making sure that the curves are flat"? Does it only happen with some images?
I have had two similr problems which I have reported, one now seems to be fixed but not the other more complicated one.
Prior to version 1.0.1.9 I found that I could reproduce something like you by toggling within History i.e. Initial Settings plus Curves Adjustment, back to Initial Settings and again forward to Curves Adjustment was losing the Curves change completely.
The second issue is to do with toggling on and off Lens Correction, which still results in random Histogram results with version 1.0.1.10
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
afx
System_Drive: N/A
Post by afx »
Tadjio wrote:Please can you explain a little more what you are doing and what is happening - perhaps with screen shots?
Naked image (I tried it on a D700 NEF), no adjustments at all. Only toggle curves on/off -> Histogram in curves tool changes.
cheers
afx
Tadjio
sound_card: Sound
Post by Tadjio »
afx wrote:Naked image (I tried it on a D700 NEF), no adjustments at all. Only toggle curves on/off -> Histogram in curves tool changes.
I tried that on a Canon 500D .CR2 file under Windows and nothing changes...
Tadjio
rlebleu
Post by rlebleu »
I tried that on a Pentax K5 DNG file under OSX and nothing changes in the histogram, but the preview images seems to move ever so slightly... Might just be a screen refresh...
maggus
System_Drive: B
Post by maggus »
hi,
just tried on EOS 60D RAW ... no issue seen in histogram.
cheers
Markus
OpenSuse 11.4 (32bit)
Dell U2410
kaymann
motherboard: ASUS P8P67 PRO REV 3.1
processor: Intel i-7 6800K
ram: 32 GB
Video Card: NVidia GeForce RTX 2060
sound_card: Onboard
Hard_Drive_Capacity: 3.5 T
Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Post by kaymann »
I get zero change as well. I get a little disk activity at first but then it quiets down through all the rest of the D/E's
gregglee
motherboard: Asus Sabertooth 990FX R2.0
processor: AMD FX-8350 8core 4600 MHz
Video Card: nvidia GTX 660ti
sound_card: on board
Hard_Drive_Capacity: 10 TB
Monitor/Display Make & Model: viewsonic vb2365WB + LG 1933TR
Post by gregglee »
thufor wrote:1. Select RAW image (doesn't seem to happen with JPGs).
I assume you mean checking and unchecking the "apply" box in curves. I can't reproduce anything so dramatic, but on/off does cause cllipped highlights to disappear and reappear on the histogram.
Which I discovered is probably a separate error. ON some images clipped highlights don't indicate (no tall spike at right edge), even when the curve is obviously way above zero at the right. I found that the tall spike is actually there, but is is hidden just outside the histogram window. If I pull down on the upper left slider, the hidden edge of the histogram comes into view. Teh width of the histogram changes slightly as I do on/off cycles.
I wonder if you are seeing a similar effect of the histogram width varying compared to the histogram window. (All of this is in the curves histogram.)
For what it's worth I have tools floating on second monitor and widened from default width.
Gregg Lee
12 miles from Glen Rose, Texas
camera equipment
binoyte
System_Drive: Z
Post by binoyte »
afx wrote:I can reproduce this with NEFs. No visual impact on the image it seems but the histogram changes....
cheers
afx
Me too with 5D mkiv *.cr2
Darktable 3. Bye bye aftershot.
nyukuri
ram: 4GB
Hard_Drive_Capacity: 500GB
Post by nyukuri »
only slight changes with Olympus ORF;
no visible changes wit Nikon NRW though...
