installing NewBlue Fx in Corel VideoStudio Pro X5
aureliensas
Post by aureliensas »
Hello, I'm French, so excuse my English.
I downloaded VS X5 and I want try NewBlue FX, but when I download trial of NewBlue, the installation ask me where install the plugin ! But normally it's automatic ? Can you help me please, perhaps it's NewBlue whoes isn't available for X5, but like i can't find any answer, i ask for help !
thanks for you help
have a nice day,
Aureliensas
Re: installing NewBlue Fx in Corel VideoStudio Pro X5
Hello
Welcome to the forums
Is this the window you are referring to, selecting Corel Video Studio should install to X5
click image for larger view
aureliensas
Thanks but installation choose it automaticly but after i need choise any way to install plugin un my computer but i don't know where installation Must be!
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Post by Kingston »
They are installed in the vft_plug folder in the VideoStudio program folder. I don't know the path where they are installed in Windows 7, but in Windows XP they are installed in:
C:\Program Files\Corel\Corel VideoStudio Ultimate X5\vft_plug
You must add the path during NewBlueFx installation. It will not automatically install into X5 unless you enter the full path. Only X4 is automatic.
Also remember that X5 comes with some NewBlueFX already. If you install the trial, you could possibly end up with double those effects in your FX library. The effects have the same friendly name, but the names of the files are different on your hard drive. I had to delete the duplicates from my hard drive, then rebuild the "ulvft.dat" file in VideoStudio:
C:\Documents and Settings\Kingston\Application Data\Ulead Systems\Corel VideoStudio Pro\15.0\en-US\ulvft.dat
To rebuild the ulvft.dat file, I rename the existing one to "ulvft.dat.old", then started VideoStudio. It takes a while for the new file to be rebuilt. You will see a progress bar as it is being rebuilt.
aureliensas
thanks again, but, with your explication, it doesn't work ! nothing is add in X5 (i try with Pinnacle and all works fine)
I think back to x4 !
do you have any other help ?
thank
Aureliensas
Kingston
ram: 8 GB
Post by Kingston »
I really can't help you because I have no idea what steps you have taken or even if you understand what I'm telling you.
aureliensas
I try to install in the good directory, but in X5 no one plugin was install so i uninstall all, clean my registry and try again, I hope that work after that ...
I am using XP but the process should be the same........
As a test i downloaded the Art Effects filter.
After downloading and installing a folder is created on C:\Program Files\NewBlue
This folder contains the filters files.
If you wish to run the installation again go to C:\Program Files\NewBlue\Art Effects for Windows\ULead
Double click InstallAssist.exe
During installation you are asked to select / choose a program to use the filter.
Click for larger image
For some unknown reason X5 is not selected, I added the path.
The install completed, on opening X5 the filter could be seen in the FX library
The filter I installed was called Art Effects
aureliensas
thanks a lot... that 's work for X4 but not very well with X5... I don't know why, but it's good !
I have a problem with newBlue Stabilizer, after it finish analyzing Corel crash !
Can you help me ?
thanks again,
Aureliensas
Kingston
ram: 8 GB
Post by Kingston »
For the NewBlue Stabilizer for Windows, you should contact support at http://www.NewBluefx.com and ask them if they could please provide you with
Version 1.4 Build 110207.
Some of the later versions don't work correctly or crash VideoStudio. I don't know if NewBluefx support will provide you with that version, but they might. That's the version and build that works for me in VideoStudio X4 and X5.
yaray0
Post by yaray0 »
lata, your solution doesn't work for me either. And trust me, I'm doing everything right. It's amazing, that since the beginning of time Corel and NewBlueFX developers can't solve such problem and waste their users time. In X4 there were some problems (eg. separate folders for some nb effects/transitions wasn't creating and you had to search for them in "All" folder), but in X5 you can't install them at all!
Black Dog
motherboard: Acer Aspire M3970
processor: Intel Core I5-2300 2.8GHZ
Video Card: AMD Radeon HD 6450 1GB
sound_card: Aspire sound card
Hard_Drive_Capacity: 1TB
Post by Black Dog »
Same here...
I can't install NewBlue: Video Essentials III.
Videostudio crashes instantly when I trie to run the program. When I remove all the NewBlueVE3.vft files out of the X5 vft_plug directory it starts working again.
Had already other blueFX installed...this is the first time nothing works.
This is what I get in a split second on the screen. Too fast to read .. I needed Print screen button several times just get it right in time.
